Stivep1: Tesla Rehash (Akula device)
Started by jbignes5, October 02, 2013, 10:19:57 PM
baroutologos
I was experimenting with a biffilar coil of mine, running it in a Kacher mode, and saw that 200 turns or so one layer in 50mm diam, 24awg enameled wire and runs at a frequency of 2 Mhz. (interwinding capacitance must be in the range of 5-6 nf)
How that acula biffilar, of 100 turns 16? awg insulated stranded wire over a 100mm PVC tube connected in biffilar mode can have a fundamental? frequency of 75Khz?
Sounds weird.
br549
I also used enameled wire (#25.5 awg) to wind a coil for testing. The below attachment shows my preliminary testing, which was done with only the bi-filar coil. I was looking at the system drawing on the previous page that shows a magnet coil and a split aluminum tube. By the way they are illustrated, I am assuming that they are below the bi-filar coil. I am thinking that they will reduce the resonant frequency, but not sure until I build and test. The magnet coil rings a bell in reference to Kapandze device. I remember reading an interview, and being ask, 'what would happen if the ground was disconnected while the device was operating'. He said that it had happened once, and caused damage to the magnet coil?
[/quote]
d3x0r
Quote from: br549 on November 11, 2013, 01:16:37 PM
I don't understand what you mean by 'a magnet coil'
br549
Quote from: d3x0r on November 11, 2013, 01:56:12 PM
d3x0r:
I'm not exactly sure why the two coils of the magnet coil circuit is connected the way it is yet?
aAs Always: have a good day
Hope
This topic is great and I want to watch it all closely.
I found an oddball link and who knows if it is real.   What matters is the theorem presented on it supposing it is the basis of Tesla's work.
Looking at this topic here and thinking about the links info I am posting.  I remembered a device that passed a signal through an ultra-violet bandwidth and the results were reported as a beam that could disintegrate even concrete and metal.
  [size=78%]Nikola Tesla's "lost" theories[/size]
Having the device presented in this topic as the producer of material that attracts the aether then bumping it to produce the so called smoke ring makes logic of what Tesla's work could be all about.   I really don't know about the in's and out's of all these devices,  but the mechanics all seem to be correlatable to the "ink ring" underwater maker.    I hope some comments on my thoughts come forth.  I don't mean to distract at all here, only add some understanding to the mechanism which may being employed that truly is causing the reactions we can measure.
