Smoothest, and best, store purchased Joule Thief I have seen yet.
Started by Legalizeshemp420, October 14, 2013, 02:28:47 PM
Legalizeshemp420
Quote from: TinselKoala on October 16, 2013, 03:58:20 PM
And... here's the data sheet for it. Up there, I mean.
Yep, I knew it was Schottky barrier diode but all parts listed in the parts list are what is on this board (Q1/Q2 were changed in the simulator because S9013 is not available).
Pirate88179
Quote from: TinselKoala on October 16, 2013, 10:26:11 AM
The black blob covers the chip.
There are more than two connections to the chip, I believe, two traces visible on the foil side connecting components and two solder blobs connecting wires.
The green resistor-like thing on the component side is an inductor.
I think this is essentially the same circuit as the one posted above with the ANA608 chip, which is tiny, barely room for the four leads. A smd version would easily fit under the blob.
Thanks TK.  I had no idea there was an IC that would run on 1/2 volt, which is about what these run down to before the lights go out.  If this chip will do this I should make a JT with one of my own coils.  I have stayed away from using chips because most of them need like 5 volts to run.  (555's, etc)  Why did they enclose the chip in that blob?
***EDIT***
LH  Thank you for pointing out the same thing.  I had no idea that green resistor looking thing was an inductor.  I have several of those in my resistor collection box from electronics that I have salvaged parts from.  I guess I need to place them in another bin.
Legalizeshemp420
Over the last 30 years whenever I opened up a China, or Japanese, cheap electronics item I almost always found that blob.  Back in the day (circa early to mid 80's) if it had a piezo speaker it always had that blob.  That blob always ended my exploration because there is nothing we can do with it. :(
What is ironic is that these chips can be ran on such a low voltage.  Look at my video where I show a square wave that makes the solar powered figures dance.  That is no battery and at less than half a volt.  Only discrete part on it is a 10v 470uf 105c Electrolytic capacitor.  The black blob has 4 connections.  2 for the solar panel (.5v) that has the cap in parallel with it and two going to the pancake coil.  It makes a wonderful square wave pulse that the time, and amplitude, is dependent upon the voltage it receives but it is always a clean square wave.
Yep, the chip is a little low-power square-wave oscillator.
Which gives me an idea. A friend of mine gave me a bunch of these:
http://www.surplus-electronics-sales.com/index.php?main_page=product_info&cPath=38&products_id=589
They need a 5v supply but make a very nice accurate and clean square wave output.
