Blocking Oscillator fun and surprises.
Started by Legalizeshemp420, October 18, 2013, 10:52:15 PM
Legalizeshemp420
Your scope trace shows 7 peaks in 8 horizontal divisions. So that is 7 / (8 x 0.5 microseconds) = 7 / 4 microseconds = 7/0.000004 sec = 1.75 MHz.
It looks like your counter is the one misplacing decimals.
ETA: So you are using a 10x zoom in the first scopetrace? Why did you not say so when I asked you what the timebase was?
It's hard to discuss stuff, without a schematic or the correct information about your scope settings.
Legalizeshemp420
Quote from: TinselKoala on October 19, 2013, 01:27:43 AM
I didn't know what my scope was at until I just used it for the picture AND I counted almost 9 within a division.
5e-7/9=18000000 so that is pretty much what I am seeing on the scope.
Legalizeshemp420
Quote from: TinselKoala on October 19, 2013, 01:14:18 AM
OK. That is 0.0000005 second or 500 nanoseconds per division. Right?
So what is the period of a 17 MHz signal?
1/17,000,000 = 0.000000058 = 58 nanoseconds. So a 17 MHz signal should have 500/58 = almost nine peaks per horizontal division.
Right? Or did I drop a decimal point again?
You dropped a decimal point as 1/0.0000005 = 2mhz not 20mhz so just add one more zero 0.00000005 to equal 20mhz.
Legalizeshemp420
I could run up a schematic but I have no way of knowing what the inductance is of my coil.  I use a toroid with 24ga (seen in the picture and video) wire wrapped twice.  The toroid came from a 100watt equivalent CFL.
In my circuit you see on the video it is using a S8055 transistor but I just tried a BC337-25 and it was even better except at lower voltages where the S8055 beat it.  Same beautiful waveform but about 200khz higher frequency using the BC337-25 at 1.2V
When I simulated this circuit it did not behave as irl.
