Joule Thief behavior question.
Started by Legalizeshemp420, October 24, 2013, 03:04:05 AM
Legalizeshemp420
Quote from: xee2 on October 26, 2013, 03:47:15 AM
Paralleling transistors is like paralleling resistors. The more you put in parallel, the lower the e effective resistance will be. However, paralleling transistors can be tricky. I recommend only paralleling identical transistors.
So, there is no way to know what numbers are changing so you can go out and look for a transistor that has the same specs as the multiple ones in parallel end up having?
xee2
Quote from: Legalizeshemp420 on October 26, 2013, 03:59:33 AM
When using identical transistors, every time you double the number of paralleled transistors the effective "on resistance" is cut in half. However, paralleling transistors is usually done to allow switching a current that exceeds the maximum collector current spec.
Legalizeshemp420
Quote from: xee2 on October 26, 2013, 09:38:28 AM
Which value is that on a typical transistor datasheet?
xee2
Legalizeshemp420
Something isn't making sense.  You show the collector current of 1.5 amps so if I put two of those in parallel you said that would be cut in half so that would make it 750ma which i not good.
