Reactive Generator Research for everyone to share
Started by gotoluc, November 15, 2013, 04:51:05 PM
e2matrix
Thanks RomeroUK and Groundloop for the schematics and info.   I had assumed that was how Luc is wiring things up but I really like schematics ;)
gotoluc,  I'm sending you a PM with a document (or a link to it) that may be of interest to you in this study.
gotoluc
Quote from: Groundloop on November 16, 2013, 07:25:22 PM
Luc,
Thank you. Can you think of a circuit drawing for a solid state setup?
I was thinking of using a H-Bridge driven from 12VDC to a circuit that is tuned for reactive
power. Then to a output tuned for the same. Do you think something like this will work?
GL.
Hi GL,
as you know I do have an H-bridge but unfortunately it doesn't work!... I think because the H-Bridge is not like an output of an Inductor, so it cannot deal with the return current (to cancel Lenz) of a reactive circuit. So inverter and electronic switching components won't work. The only thing I can think of is those old Inverters that used a output transformer... it may work?  but I don't have one to try. Don't you have one that you designed and built a while back?
Luc
Groundloop
Quote from: gotoluc on November 16, 2013, 08:36:00 PM
Hi GL,
Luc
Luc,
Yes, I still have the 40 Watt inverter that I did build. It uses a 1/2 H-Bridge (two mosfets) to switch
a toroidal transformer. I can get the same inductive output from a full H-Bridge by connecting a 1:1
transformer on the output. Will that work?
GL.
gotoluc
Quote from: Groundloop on November 16, 2013, 10:05:35 PM
Luc,
GL.
You're up late!
I don't know if it would but I just realized that I could also add a 1:1 transformer to my H-Bridge and it should come the the same as what you have.
I'll try it and report back
Luc
EDITED
Okay, I can see people are getting confused and are trying to replicate my demo video. Don't start with that!  as it's very difficult and was to prove that the circuit is not fooling the power meter and also to demonstrate it has potential of looping a generator.
Start with the below circuit and instructions for your first test
The induction motor circuit is very difficult to tune if you have no prior experience with reactive power tuning. I would recommend people to start with the below test as you use the grid and a plug-in watts meter to first learn and you see results fast since I worked out most of this.
Start with a 25 watt 1k Ohm load on the secondary but no caps for now. Then start with about a 10uf Series cap on the primary and connect it to grid. Reduce or raise (if needed) the cap uf value until your power meter is at about 1 watt.  Then check your voltage on the 1K Ohm load and do the math. You should have more power out than in.
After that test, reduce your load resistor by 100 or 200 Ohms at a time and you will see you can add uf value to your primary and still stay at zero watts in. And If you raise the Ohms resistor your cap will need to be less to maintain zero watts.
You will find the ideal resistor and cap value which give you most watts out for zero watts in and you will find that each MOT is different.
After you get the hang of it try working with the below schematic and know it takes lots of time to tune to ideal levels.
All the best with your experiments and please share your results
Luc
gotoluc
Quote from: gotoluc on November 16, 2013, 10:23:27 PM
You're up late!
Luc
Okay, the H-Bridge and Isolation transformer does not work :P .... if it would there should be next to no change in DC current to the H-Bridge when I connect or disconnect the reactive circuit side of the Isolation transformer. But that was not the case. It went up when connected so I did the P/I & P/O power calculations of the increase and it was under unity.
I think I know what the problem is. Since the circuit is capacitive and current 90 degrees ahead of the voltage. I can see on the scope the current is crossing the zero line (going in the opposite direction of voltage) half way of through the voltage on time, so since the voltage is still on for the other half of the on time the current cannot go back to the source because the mosfet is maybe blocking itl. Do you understand?
Do you think it's possible to make an H-Bridge that could handle such a situation?
Thanks for your help Alex
Luc
