Bashar's Spacecraft Engine
Started by teratologist, November 20, 2013, 04:21:16 PM
Uniqorn
Quote from: WTF on February 18, 2014, 01:58:36 AM
Another reason this might not work is because the wires that go in the crystal need to be curved to continue the spiral.
Ooh, that would be harsh, if that were the case!
The total area of the hole in the middle is a very small percentage of the overall area (~2.7%)
I'm guessing that while the lack of curvature may play some part in that, it probably isn't critical, considering the accuracy of the rest of the device.
The center is already quite dense. To achieve this you would need to use tapered wires, otherwise they would bunch up and get in the way of each other.
I considered that a crystal ball cut into two hemispheres would allow this, but I'm not sure how important the continuity of the crystal material is.
Have you tried getting the rims of the hemisphere to touch the spiral mesh, all around? You could perhaps use aluminium foil to test this.
WTF
I tried with thin copper sheet, but only went half way around, just to close the gap between the hemispheres, not tried with foil but that's a good idea as I have enough to cover the whole hemisphere. But I'm thinking that since it has insulating discs, that they would be there so that the wire net doesn't come into contact with the hemispheres.
Also with the curved wires inside the crystal, I was thinking that maybe since there are 2 spiral sets that maybe 2 wires would be from 1 set and the other 2 wires from the other set so the wires would cross inside the crystal as they do on the wire net.
Hope
What I was thinking was your plastic clear insulating disk look very thick when compared to the null region (center) of a bar magnet.  My thoughts were to make it closer to that.
The null force (*that is moved by the natural occurrence of wavelengths all around us) may generate static charges while moving across the dielectric insulating disks.  So if one moved in the opposite spiral it may be logical that that charge would also be opposite of the other disks static charge.
* Imagine wind blowing is the wavelengths and a sheet hanging (the null) in that wind is moving  due to the winds force.
Spira mirabilis disk flipped over.
WTF
I tried the foil, but made no difference, but that's not going to as good as thinner discs, I will make some discs out of 1.2mm thick card with a smaller rod and try that.
WTF
This is with 1.2mm card as the insulator disc, this also never worked, but I never expected it to as I think the hemispheres are there only to make the received energy usable, it's the wire net and crystal that picks the energy up and then sends it up the rod where the energy gets transmitted to the hemispheres, that's why I think the insulator disc thickness isn't that important.
