How to make multiple Kicks
Started by Neo-X, November 23, 2013, 10:31:20 PM
Farmhand
Quote from: MileHigh on December 05, 2013, 07:04:51 PM
Rosphere:
What's your point?  Just go ahead and state it and I will be pleased to respond.
I think he was having a dig at your grammar in the last paragraph. I often fail to use good grammar as well.
cheappower2012
Meggerman
Here is how the 4 inch TPU was done,however,heres some advice this does not
mean that other TPU's are fake to take this opinion is not a good idea.
SM doesn't think in a conventional way,the use of fakes, is to sweeten the pie,
to appeal to the greed of the investors,to make them  believe there buying
a way to make small TPU's.There is a size limitation,real small devices were not possible.
The conventional view is you faked one, you must have faked them all,this is not how
SM thinks,hes thinking is
if they think I can make small ones, I can land the sucker investor,since I have real
devices no one will question the fake ones,once I get hes money ,I will burn him and give him nothing.
I dug this up its been laying around,I made this a long time ago.It is 11, 9 volt
alkaline batteries connected in a circle,the light used is a 100 watt bulb,it will light a 100 watt
bulb for the time its on the video about a minute,the batteries are run down now.The batteries he could get at Radio Shack in 1996.
Now the humor in this,he pretends it vibrates,claims a magnet starts it,the magnet sticks to the battery case,then he turns it upside
down to reinforce the belief it can't work upside down,LOL.Remember SM can't lie ,wouldn't lie
and wants you to build hes TPU,LOL.
Bruce:
There is no moderator in real life and I haven't done anything wrong.  You are claiming a leadership position and I recall that several months ago you were going to charge people a monthly fee to follow your experiments so you could buy parts and stuff like that.  So you are a semi pro and you should in an ideal case be able to respond to the technical points.  But in fact you are unable to respond so you try to claim that I am all "hot air."  That's simply not true.  I know that you are emotionally involved in what you are doing.  But if you believe in what you are doing why don't you try to defend your position with a technical argument?  You believe that you can tap into the Schumann resonance and get power like that?  Then prove it with an argument and experimentation that backs up your argument and show some tangible data.  But you can't do that, can you?  We are all just supposed to take you at your word for it and apparently some people even have to pay for that privilege.
I looked at Giantkiller's clip.  He lays a scope probe near his coil setup and picks up some ticks.  You tried to claim that that backs up your research.  But in fact, what I said is the real truth.  I said that it's just standard signal coupling into the very sensitive high input impedance scope probe input and it means nothing and it's all normal.  I have seen it all my life and have thought nothing of it.  That's an example of how you are so focused on what you are doing that you are attributing perfectly normal effects and trying to claim that they are something special and related to your claim.  When you start doing wrong things like that you are leading yourself down a garden path.
The fact that I don't have a scope is inconsequential.  This is the second or third time I will state this:  I have thousands of hours of experience working on an electronics bench.
Quote3.  Asked a member of this forum to perpetrate a hoax on the communit to "teach" them a lesson.
Why?  Because he is a fraud.  Phony.  Fake.  This is fact.
That is a disgusting lie and you should be ashamed of yourself for stating that a second time when I already refuted that point before in clear and unambiguous terms.  I have never perpetrated a hoax or asked a member to perpetrate a hoax on anybody on the forums and if what you were stating were true you would be able to cite links to back up your claim.  But of course you can't cite anything because it's not true.
I will repeat to you again Bruce:  Twice now you have alleged that I have committed fraud or encouraged inappropriate activity and it's a lie.  You have no evidence at all of that.  It's probably your emotional state in a kind of panic and all that you can do is make untrue allegations against me.  It's totally unacceptable and do not do it again.
The real reason I am here is just for fun and to debate and to sometimes help people.  I have designed one of the the most sophisticated pulse motors ever seen on the forums.  I just proposed a variant on a Joule Thief type of design for an LED lamp and again, it's one of the most sophisticated designs ever seen in the realm of Joule Thieves.
I am just giving you the real deal as far as I see it.  You have ignored every request from myself and others to show something with tangible results.  That's not a good thing and I will assume that you are hoping that you will find the "magic configuration" that does the trick.   Sadly, the "magic configuration" is just another tired worn out cliche that I assume many people that are hoping for positive results are also getting tired of.
Magluvin
Quote from: MileHigh on December 05, 2013, 11:14:36 PM
"You have no evidence at all of that."
But I do. ;) ;D :o
http://www.overunity.com/12147/this-might-blow-your-mind/msg315414/#msg315414
:P
"Mags:
The reason you would want to make a motor that runs on a concealed battery would be as a lesson for others.  Too many people look at clips like that and they believe that they are real.  That's how the Perendev motor guy got rich and then got busted and is now in jail.  To be honest though that is secondary to my main point.  My main point was to use your scope and your wits and construct a timing diagram for the device.  Show the voltages and currents induced into the circuit as the magnet rotates.  That would not be easy for most people to do, it's a challenge.  Then you explain the timing diagram and that explains how the device works. It also would clearly explain how it's impossible for the device to work unless you add a battery.  The whole point is to demystify the device."
Then I said...
"Ok, first off, How many people here would rather that I, Magluvin, build a fake Z motor, rather than build one that might work for real?   First sentence. Easy one.  ;)
Im for the real deal. Trix are for kids.  ;)
Next
If too many people look at vids like that and believe they are real, do you not think that there are many other videos out there already doing just as you suggest that you could refer them to? Advertize those why dont you. I dont need to be reinventing the wheel, when there already is plenty to choose from. It doesnt get me any closer to my original goal, it delays it.  8)
I need to spend my time doing what this site here is intended for.  True Dat.
I am not Prendev. Im not taking investments. Im not building fakes.  Open source dude. You can google it. "
;D   The truth shall set you free!  But not a drop to be found. :P ;D
Mags  ;)
Magluvin:
I told you to NOT ENGAGE WITH ME ON THE FORUM because it quickly becomes a pissing contest and then you get abusive and call me names like "Idiot" and "Freak" over and over and I told you in no uncertain terms that it was unacceptable.  You have never had the character to own up to your unacceptable abusive behaviour and apologize for it.
Here is an example:
Here are some of your comments:
"That vid you posted is malarky with math to explain the malarky. People deserve the truth, and that vid isnt it."
"If I see you preaching garbage, I will respond."
If Bill had posted the link to that same clip, would you have commented like that?
If Poynt had posted the link to that same clip, would you have commented like that?
If Farmhand had posted the link to that same clip, would you have commented like that?
If Brad had posted the link to that same clip, would you have commented like that?
We all know that the answer is that you would never had made comments like that.  This sick abusive behavior from you has to stop.
In one of the three waves where you relentlessly and viciously attacked me for weeks and weeks on end you called me a "freak" between half a dozen and a dozen times.  Then in another of the waves you called me an "idiot" perhaps 20 times.
You tell everyone right here and right now why you called me a "freak" on a public forum.
You have better get it through your thick head that I don't want you to engage with me at all.
Here is your quote again from me 1 1/2 years ago:
<<<  The reason you would want to make a motor that runs on a concealed battery would be as a lesson for others.  Too many people look at clips like that and they believe that they are real.  That's how the Perendev motor guy got rich and then got busted and is now in jail.  To be honest though that is secondary to my main point.  My main point was to use your scope and your wits and construct a timing diagram for the device.  Show the voltages and currents induced into the circuit as the magnet rotates.  That would not be easy for most people to do, it's a challenge.  Then you explain the timing diagram and that explains how the device works. It also would clearly explain how it's impossible for the device to work unless you add a battery.  The whole point is to demystify the device."  >>>
But of course you leave out the context.  We were discussing a fake motor clip on YouTube.  So I suggested that one way to educate people would be to emulate the same clip by building a comparable fake and then explaining to your audience how you built the fake.   The point being you are trying to do something positive by exposing a fake and showing how easy it was to do so that your audience would be that much wiser and learn from the experience.
Then you take that positive and take it out context and try to spin it as me having committed fraud or having encouraged inappropriate activity.  And of course it's not true but that doesn't seem to matter to you.
You are a morally bankrupt individual.  You think you see an opening to "get at me" so you go back 1 1/2 years and post something out of context in a failed attempt to make me look bad and make it look like I was lying and contradicting myself.  You are one pathetic desperate spin doctor with no morals and you will do anything you can go get at me, even if you have to make yourself look like an obsessed fool.
You fucking asshole Magluvin, what you just did illustrates precisely why I told you to NOT ENGAGE WITH ME ON THE FORUM.  What you just did is pure low life sleaze in a stupid nonsensical and untrue attempt to impugn my character.  You are fucking pathetic and stay the fuck away from me.
DO NOT ENGAGE WITH ME ON THE FORUM.
