Gas, Heat, Water and Hydro. Overunity cant be escaped.
Started by DaS Energy, December 11, 2013, 06:56:21 AM
Hello Peter, a. related : do you use the "Description"-function or the "original document" ?
b.related: I please you for pardon,my fault.More then one decade before  I only have copied one page to paper from the delivered "patent" and I have thought that the  temperature/density relationship would make part of the total document, what is not .
Probably it will be find in the Fisher-engine papers. I will search for the right link.
Here a relatively cheap ceramic tile as "heat deposit/storage" for thermocyle-engines:
https://web.archive.org/web/20100411055920/http://www.io.com/~frg/history.htm
Sincerely
             OCWL
DaS Energy
Hello OCWL,
Thank you for the information, I gather so much and occasionally that I read prompts new developments.
I quote when referring to things not of our design. In the post I refer to the 82% efficient Francis and Pelton turbine. Kilowatts needed to heat one litre of water by one degree in one second is quote from Wattlow Industries America. Both web sourced.
The heated CO2 supplies the pressure to the water until the CO2 is released to the condenser where the natural refrigerant effect of the CO2 comes into play and goes cold.
The attached is one example of how all is done. Please note the vacuum left behind as the water leaves the condenser drawing in cold CO2 to the heating chamber.
Sorry about the attachment, should only carry 82% energy conversion water.
Peter
