Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
d3x0r
another generator/motor setup
http://peswiki.com/index.php/OS:_Nigerian_QMoGen_Plans
[/size]U.S. Patent 7,095,126 B2[/size]
pdf attached
alternator/generator;  He claims the magic is in the 60W lightbulb connected to one 400W inverter which is connected for loopback; and running another 1200W inverter for external loads.
(Although at a glance looks like gotoluc has been pretty forthcoming with all information already :) )
allcanadian
@D3xOr
Quoteanother [color=rgb(27, 142, 222) !important]generator[/color]/motor setuphttp://peswiki.com/index.php/OS:_Nigerian_QMoGen_Plans[/size]U.S. Patent 7,095,126 B2[/size]
I think the patent is a red herring, first there are hundreds of motor/generator patents that utilize inverters as such they are prior art not disclosed rendering the patent null and void. In fact nothing new in any way has been disclosed relative to the prior art that already exists rendering the patent void. As such I have no idea why a patent would be granted however it is from Nigeria = run away, run away.
AC
hartiberlin
Quote from: poynt99 on December 17, 2013, 09:57:41 AM
Here are some simple diagrams I made a while ago to explain this same power polarity issue to Rosemary Ainslie, because she had (has) the same mental block about this.
poynt99, This would be only valid, if we would be discussing i^2*R losses inside the Generator or the
power losses inside a battery inner resistance, which does not apply at this
circuit over here. So a BIG NO to inverting the 2nd channel on the Scope !
We really need to see the input power into the LCR tank circuit and so we need the scond channel not to be inverted !
Regards, Stefan.
hartiberlin
hartiberlin
