Charging battery from mains is series with a capacitor
Started by nilrehob, December 19, 2013, 10:51:19 AM
Groundloop
Hi .99,
Does you simulator have a battery simulated, or did you simulate a capacitor on the output?
Batteries has a high internal resistance when depleted. Capacitors has a low resistance when depleted.
So if you simulate a "real" battery on the output, then the current usage from the mains will start
out low and increase when the battery gains charge.
GL.
poynt99
GL,
I simulated a partially depleted battery with a capacitor as shown.
The capacitor was charged to 12.5V at the start of the run, so it emulates quite nicely a partially depleted battery. A real partially depleted battery when charged with a constant voltage (within its spec'd current) will draw a higher current initially, then taper off as the battery terminal voltage approaches about 1.2V or so less than the charging voltage.
This simulated battery is basic and not a real battery (I never claimed it was), but for all intents and purposes, it serves well to demonstrate the intended teachings.
Condensator/Capacitor as Diode: LED=Emissor to Diode-array=Solar-diode=cell-modul             n and p polarity ?
and :
0006] From OSRAM has been explicitly confirmed to me(to H.D.W. Goeres):
1 cd = 1 candle light abundance; Watt earlier, the light intensity giving a tungsten wire lamp.
ENERGY SAVING LAMPS deliver high cd (candelae), with minimal smaller wattage recording.
[0007] 6000 cd halogen lamp is equivalent to a tungsten light 6000 candles wealth of previously several lamps of 6000 watts together luminosity.
                                         ENERGY SAVING LAMPS like L.ight E.mitting D.iodes
                                                             Watt per candela
                                                              candela per Watt
Emissor f.e. : http://www.tradekorea.com/sell-leads-detail/S00024711/LED_flat_panel_light_600x600_.html#.Urg5CuWWjh0
                                                     for shift=Verschiebung/Blind-current stimulation
Receiver/Converter: http://www.about-solarenergy.com/wp-content/uploads/2011/10/how-solar-power-work.png
        Tandem-Junction
Sincerely
             OCWL
poynt99
a.king21
"Me thinks some people protesteth too loudly."
Shakespeare.
Thanks nilrehob and gotoluc
Merry Christmas too all.
