Lenzless resonant transformer
Started by Jack Noskills, January 17, 2014, 04:58:15 AM
itsu
Quote...and anything below the X-axis means, that the DUT is returning energy to the signal generator.
like negative resistance, a negistor?
Or do we have here a severe case of reactive power versus real power?
Guess that the returning energy never will be more then half of the total energy
Thanks,  regards itsu
verpies
Quote from: itsu on February 28, 2014, 10:57:48 AM
No, no ...more like a charged capacitor discharging itself back into the signal generator.
Inductors can do it, too.
Magluvin
Quote from: verpies on February 28, 2014, 08:49:29 AM
If this large 3rd coil was physically rotated 90ยบ so it would be encompassing both the primary and the secondary windings, then you would be able to detect the induction caused by the leakage flux spilling out of the core.  The more current flows in secondary, the more voltage is induced in this 3rd winding.
It is just a neat trick to detect how much flux leaks out of a transformer's core.  It has a large educational value.
P.S.
As always, the even number of layers of back&forth winding rule designed for pitch-current nullification, applies to all windings.
I think a better way to measure the field leakage of a toroid core in operation would be to us a coil that I added to the pic you posted above.  It should not be in direct physical contact with the toroid windings or core.
Mags
dieter
So, Verpies, let me get this straight, the scope shot says "OU"?
verpies
Quote from: Magluvin on February 28, 2014, 07:34:04 PM
Yes, this will work. too and it will avoid capacitive coupling.
Alternatively, such leakage detecting coil can be placed inside the toroid's hole (please make a pic of that configuration, too, for completeness and for the future).
