Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
MarkE
Quote from: forest on February 07, 2014, 03:25:13 AM
Don't throw the idea so fast , look at the actual placement of magnets.They should have been in 45 degrees so the attaction and repulstion work together to push magnet while at sticky point there is balance between N and S forces and should be very low summary force.
Forest, the best that one can do is to have no field at all.  As soon as there is one or more magnets there is a reluctance gap and there will be a position in that gap that is a PE minimum.  You can ignore the physics and if you like join the leagues of experimenters who have spent lifetimes trying to come up with clever arrangements that get around the PE minimum, the so called "sticky spot".  You do not stand to fare any better than those who have gone before you.
dieter
That does't mean you can't have a pmm. When there's a third pm element that oscillates, the sticky point can be neutralized. It's really more about a temporary imbalance between the pole forces of the pm. Any further PM will have no additional force effect btw.
MarkE
Quote from: dieter on February 07, 2014, 07:09:30 AM
Dieter by definition your oscillating PM has to change the PE of the object it affects.  It is therefore conveying energy to that object.  You have now moved the problem of the free energy source to the oscillating PM.  We can move the pig back or forth in the snake, but it still gets digested.
dieter
There may be ways to alter the field by using quantum mechanics where the energy requirement is not linear.
Or in a dual system one side could use negative energy, the other side positive energy, compensating eachother. Negative energy?  :o
T-1000
Quote from: MarkE on February 07, 2014, 03:54:24 AM
Seems you do not know what Gary Effect is - http://www.linux-host.org/energy/tmagnet1.htm
Also the tricky part is precise engineering for magnetic switching between two magnetic poles and not magnetized metal(which is giving resulting magnetic pole)  between them on same metal cube cast and many failed to do that.
Only few people was able remove obstacles for making it to give energy out of the magnetic field:
http://searlsolution.com/technology2.html
http://www.rexresearch.com/sweet/1nothing.htm
http://peswiki.com/index.php/Directory:Leedskalnin_%22Perpetual_Motion_Holder%22_%28PMH%29_Bond_Effect
P.S> Please feel free to create separate thread for people who are willing to do lots of hard work for making magnetic motor a reality instead of just having the dream. The community can achieve this like with any other open source science project as there are brilliant minds around the world who can make a difference if they will share and work together...
