Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
deanc5000
Again, its a clear fake. Where are the parts that I have highlighted in red in this photo of a typical generator? There are many glaring giveaways in the second video shot outside...
-The apparent light weight of the unit as he lifts it and manipulates it. - no rotor in the generator.
-The trouble they go through to place the board in a very specific spot on the ground, tweaking it mere cm till its just right.
- the lights turning on and off instantly.
- the guy stopping the rotor with his hand as soon as the clamshell opens to cover the fact that the lights go off instantly. And if it were a real generator, the mass of the rotor would have injured him badly.
- no torque is apparent on the spring coupling, let alone 3.5kw. Would that spring drive your 5hp lawn mower? Think about it.
So not only is this a fake, it is a particularly bad fake. I don't know why I am compelled to expose it, but reading the posts by people who swallow this crap is annoying. Thats all, move on.
Hoppy
Quote from: T-1000 on February 03, 2014, 03:48:11 PM
The better offer would be to make clear statement in fb for him on public page - to disconnect all electric parts including generator and attach some heavy weight to lift up right on magnet motor shaft. He can control easily when to stop so the weight won't be swinging around shaft after rope is pulled.
Then serious engineers could go there to investigate this setup.
::) C'mon! No serious engineer would go anywhere near that silly setup!
NTesla
Quote from: crazycut06 on February 03, 2014, 05:53:12 AM
I was reffering with this video, the wires are hidden underneath the soil where he nailed the motor to make a connection from mains.
Hidden wires (externally) are not required. The 'alternator' has enough room to hide a small motor connected to the magnet generator plus the battery to both power the generator and the loads he is using. Modern batteries e.g. NiMh or Li-poly types are compact and powerful enough to fit in the 'alternator' while powering the loads in question. TinselKoala's pic shows that there is no end-to-end shaft going through the 'alternator'. Instead, a clearly incongruent, aluminum looking plate hides the insides.
T-1000
Quote from: Hoppy on February 03, 2014, 06:05:01 PM
"keep it stupidly simple" - if you would have self running magnetic motor, no electrical parts are needed for a proof as mechanical measurements are enough ;)
What I already wrote on Facebook:
Yes, Wasif, the problem is we have had  over the years many fakes, like the Mylow story, the Perendev scam and the Yildiz guy not coming forward and hiding the inner working of his motor and having cables coming out there, etc..
so Open Sourcing would be great and probably the only solution to a widespread acceptance in the conservative science community ...
What still concerns me is the fact, that when he put the clamp around the stator magnets and thus reduced again the distance of the stators versus the rotors, the motor speed did not change or drop...
I still believe the generator might still be a motor and just drives the Perendev style unit and that there are hidden batteries somewhere inside the double wood boards....we need to see the motor alone spin up  for at least a few seconds !
Come on, if the Perendev style motor is really working, you could easily show it without the "generator" by just controlling the stators with your hands and just show for a few seconds, how the rotor will selfaccelerate, when you press the stators together...
Also in the first Video I hear a hum noise which is simular to the noise a starting motor makes...so I think the generator is really a motor being powered by a hidden source..
