mrwayne
Quote from: Marsing on March 03, 2014, 11:23:47 AM
Eout - Ein =  extracted energy,  and of course with full cycle
do you have a self running machine ?
With Respect - I am sharing what I am not contractually bound to reserve.
Our Contract gives our Benefactor exclusive rights to first utilization of the manufactured models and their absolute first public demonstration.
Previous to that contract, we allowed a Skeptic to video our early model.
The Link has been posted.
Thank you.
MarkE
Quote from: mrwayne on March 03, 2014, 08:34:07 AM
The Ideal Analysis gets the calcs in your math right. Well Done.
...  Wall of pointless blather ...
Wayne Wayne Travis
President
Zydro Energy, LLC
Mr.Wayne@ZydroEnergy.com
Ah another wall of BS text from the shameless huckster Wayne Travis.  One might wonder why oh why is Wayne so anxious to try and deflect the analysis that shows that even under idealized conditions, the ZED is less useful than a brick.
Maybe the lying huckster wasn't completely honest with us about his investment situation.
Maybe the lying huckster has some fish he is trying to reel in and he doesn't want them to see the empty bag he is trying to trade them for their cash.
Note that in his entire wall of text, Wayne Travis cannot refute anything in the analysis.  Note that in the entire wall of text Wayne Travis fails to bring in any actual new information that supports his false claims of getting free energy by cyclically lifting and dropping weights.
mondrasek
Quote from: MarkE on March 03, 2014, 02:54:13 PM
MarkE, one might wonder why you are ignoring my two posts that point out a mistake in your presented values as well as a couple in the methods in your final Stage 3 presentation.  It is an invalid "Energy Balance" Analysis, as well as completely ignores that works was done in the form of F*ds.
MarkE
Quote from: mrwayne on March 03, 2014, 08:57:19 AM
To All;
... Wall of text ...
Since the inception of the NET Energy producing system - We worked hard to develop the systems, business, contact, and friendships.
I have put up with the nonsense from TK and his bandwagon now for two years for this reason.
Now we are hiring, we have Turn Key funding. We have selected 18 of our start up of 27 members.
We are hiring now, and we have temporary offices while our world class LEED building is being built.
We have Patent application pending in almost every county - some granted - some being exercised.
If you are interested in Clean and Green energy future - that has the only Alternative ON DEMAND CAPABILITY:
Welcome, our door has been open.
Wayne Travis
ZydroEnergy.com
Those are just more lies from you Wayne Travis.  You do not now have and have never had a device or a method to generate net energy by cyclically lifting and dropping weights as you claim.  The analysis of the "ideal ZED", the device model that you so glowingly approved, shows that the device is completely useless.  You can post as many walls of text as you want.  What you cannot do is get that ridiculous contraption to even match the efficiency of a brick.  Each time one goes from State 2 to State 3, a transition that performs no useful outside work, one loses 28% of the internally stored energy which must be replaced in order to return to State 2 to set-up for the next futile cycle.
mrwayne
Quote from: MarkE on March 03, 2014, 03:02:12 PM
I am sorry MarkE,
You seemed to miss this post. I will post it again.
MarkE,
I will act as you were never told the states, again, again and again - for sake of time.
So lets get your states set up, and in order.
Conditions
At least three layers and Pod each ZED:
ZED A Sunk remaining head due to riser weight and any added weight - ZED A  will be the receiving ZED,
ZED B is at the end of delivering a load and in the raised position - and was not allowed to Bob up after the load was removed.
State one - Start with sunk - still head remaining - equal to the weight of the risers - and any additional load. (additional load is sometimes used to reduce time by reducing expansion and contraction during cycles)
p.s. Adding weight is counter intuitive - most people assume adding weight induces losses
Lesson to be learned - trying to achieve Ideal usage results in self determined conservative process.
The next state is post free flow - this is where the other ZED A and B have equalized between the stroked ZED and the sunk ZED. No riser movement in either ZED - only fluid and pressure.
Note: Free flow results in equalized pressure - but not equalized volume.
The next State is changing from Free flow too "precharge"
Full precharge is the end of the state between free flow and enough buoyancy to nuetralize the determined load and no riser movement either ZED.
The process to get to the full precharge state - two inputs are utilized :
One - the continued consumption of pressure from the ZED B - and the hydro assist.
The hydro assist adds enough pressure - that when combined with the exhuast from the other ZED - reaches load neutrality (buoyancy). This is full precharge for ZED A.
Note: ZED B will not sink until the stored head has dropped below nuetrality of the risers and any added weight.
The Hydro Assist continues to be combined with the Pressure from ZED B - the input cost is the differance between the sinking ZED pressure and the stroking pressure required.
The next state is the Production Stroke of ZED A. ZED A stroking and ZED B sunk is the first half of a Dual ZED cycle - the process repeats in the other direction - notice I did not say reverses.
To understand Stroke - you must determine both the proper load and the proper stroke.
The proper load is the lift safely available at the determined end of stroke.
Iterations are helpful..... I will give you a rule of thumb - Do not make the stroke longer than 1/11 the height of the ZED.
(another counter intuitive - short stroke is a more efficient process)
Use your baseline calculator already prepared to determine what the load is at that height - and that is a good load - presuming riser weight and any added weight has already been considered.
Unlike the states Mark described - the precharge and stroke is only released into the other ZED - not bobbed up or consumed as production.
The transfer of the precharge and Stroke is made mechanically more efficient as Webby described and posted two of our methods.
but you do not need to add those improvements to find the outcome.
Last notes - when the full precharge is reached - any additional volume input into the ZED A results in production - so once precharge is hit - no consumption of the previous pressure occurs - the ZED B hits bottom at the end of the production stroke on ZED A.
In simple observation - the true cost of a stroke half cycle is all of the Hydro assist - which is also the stroking Pv ZED A, minus the sinking ZED B Pv, and then repeat for a full cycle.
The production cycle is both ZEDS having produced once and combined.
A full cycle is a return of ZED A to "Sunk.
MarkE - if you do understand these States - you should be able to see how we transfer two sets of PV left and right - not consuming that value and truely reducing the total input cost - the remaining input cost is the hydro assist.
Lastly - the Hydro Assist can be a external input - or powered by the Production leaving excess. When you determine the cost of the Hydro Assist versus the production - you will understand why I have been so patient.
The Excess or Net per half cycle is no more than the value between the Pv sinking and the production - Not magical - but free.
http://www.youtube.com/watch?v=q-0TITC4Wrc
Wayne Travis
President
Zydro Energy, LLC
Every time you or TK, or the puppets come back.
