how to creat pulse-motor with capacitor - selfrunning?
Started by rstergar, February 17, 2014, 03:49:28 PM
QuoteI put a £100 000 on the table
No you didn't, you liar. All you did was to MENTION it. Putting money on the table looks like this:
http://www.youtube.com/watch?v=-IaY-mIPMzw
So let's see your PROOF of even having a hundred thousand pounds to play around with. You can't do it, because YOU DON'T HAVE IT.
QuoteWE ARE TALKING ABOUT A STUPID REED SWITCH ON YOU-TUBE MUPIT ! And let me inform you again I have set the challenge now you prove your self and bring any heap of junk that you have made to beat me ! I can produce 750 000 000 hz can you ? no !
LOL! That gets another ROFL for sure, you blowhard idiot. Read what you said about reed switches. And if you don't think I can produce a 750 MHz signal AND MEASURE IT ACCURATELY.... then let's see YOU do it first.
Here's my Frequency Counter. It has a 1.5 GHz range and nine significant digits of precision. Where is YOUR test equipment? Nowhere, that's where.
dieter
You're right about the reed swiches, they tend to break soon. Must fit the used Wattage, best used only to trigger a transistor that drives the coils, but then a hall effect sensor could be used anyway. Or optical: A little mirror on the rotor could reflect an led to a photosensor and that sensor could trigger a transistor.
What exactly did you mean by "pickup coil"?
ltseung888
