Tesla Grounding Issue
Started by Jeg, March 05, 2014, 05:47:03 AM
Farmhand
A virtual ground might be good. You should note that the virtual ground device is for certain frequency bands and needs adjusting within that band to get your frequency. A regular ground is not really DC or AC, the house ground is for the AC system, the virtual ground has a certain power rating as well.
Another way to go is to just make two identical coils and connect them together by the bottom of the secondaries.
The second coil kinda acts as the counterpoise but it can be used as well.
Counterpoise (ground system)
http://en.wikipedia.org/wiki/Counterpoise_(ground_system)
Or a bipolar coil (sphere each end) requires no ground.
A good stake in the ground has a high power rating I think,  ;D I forgot to mention I planted a tree right next to the ground stake which is now about 12 feet high, I guess I should trim it down in case of lightning. Looks to me like the Earth stake and the tree both have a pretty good grip on the same bit of ground. A strike to the tree might go to the ground stake then inside my hut to the coil and ping the coil so that flames leap from it. hahahaha That could be scary. Virtual ground sounds good.
Cheers
The bipolar coil with spheres on both ends will work a treat if you ground the center winding and tune in that condition.
Farmhand
Yes Tinsel it sure will, and in that condition it would be tuned like two opposing 1/4 Wave resonators wouldn't it ? Which might require additional tuning of one side to match the other precisely, this might only require a grounded capacitor plate to be placed in some proximity to the higher frequency side.
Cheers
