Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
ramset
Funny stuff about Kentucky..I believe that's where I first heard it too, was doing a magnesium lance train derailment repair for CSX on concrete railroad ties ...in a dry county  [alcohol outlawed],
a ruff crowd to say the least [Athol or Lee county ??]
"don't take to kindly to NY'ers  out that way... ;D
as far as harvesting Lightning.. that's not really what I'm talking about.
getting to that energy prior to it becoming a bolt or harvesting as Tesla had stated
two men working in the field could call the power to them. the wheel work of nature !!
Chet
Thanks Grandma
Quote from: NickZ on April 05, 2015, 11:01:52 AM
   TK:
   You have been talking about this, as if YOU can already light any amount of incandescent bulbs, from some hidden transmitter (of any kind). But, have never, ever SHOWN how this could be done, when there is no such transmitter ANYWHERE close by.
I'm not talking about lighting LEDs, as they can be lit with practically no power, just some fluffy voltage
  So, then, can YOU light 5000w worth of INCANDESCENT 1000w bulbs like Kapanadze did, from a radio transmitter station, or hidden Tesla coil, or any other type transmitter, to prove your point.    NO???
So, that must prove that it can't be done, right? because you can't do it?
  Tesla did say that it could be done, and was working on it, until he was stopped.  So, it probably can be done, but only Tesla knew how to do it.  Although, I doubt that was how Kapanadze, SR 193, Stepanov, Akula, Ruslan, and others did it, to light their big 1000w incandescent bulbs.
But I can do that thing. Send me enough money to build the necessary apparatus and I'll be glad to show you how. In fact I have been giving you advice in that direction for quite some time... advice that you evidently ignore.  My videos of wirelessly lighting up incandescent bulbs on a small scale are easy to find. With enough funding I can make larger transmitter systems and duplicate any performance of Akula or Ruslan or Kapanadze at will. The difference between me and them is that I don't fool people into giving me money to show them what they want to believe. My small-scale, low power demonstrations are  just that: small scale, low power and _repeatable_ by anyone with a few dollars and the knowledge to build them. In stark contrast to the claims of those others. My demos are readily "super-sized" if one wants to spend the money and time to do it.
You talk about "when there is no such transmitter ANYWHERE close by" but that's a strawman and assumes things that are not in evidence, like the absence of such transmitters nearby the demonstrations of Ruslan, Akula, and Kapanadze. You do know, I hope, that Ruslan is associated with a commercial FM radio broadcast station and has access to the transmitter room and antenna structure of that station, don't you? And the higher-powered Incandescent Bulb displays from those people are more likely done with hidden hard-wired connections anyway, not line-cast wireless power, just as you say in your last sentence.
http://www.youtube.com/watch?v=Lb1UpX0-Q00
Quote from: Enjoykin on April 05, 2015, 02:09:19 PM
Hey TinselKoala
RIDE THE WINDS OF ETHER - LIKE TESLA DID  ;D ;D
https://yadi.sk/i/tAW1jRzofGxiH
https://yadi.sk/i/fGeje8FzfGxgm
https://yadi.sk/i/BbzDwBhxfGxgj
I prefer to deal in reality, not fantasy.
When you can produce a Komarov etheric lantern that runs itself in "loop mode" I will be happy to evaluate it for you.
itsu
Quote from: TinselKoala on April 05, 2015, 09:59:34 AM
Thanks, I was actually surprised at how well it worked in this "receiver" mode. It's as if it were deliberately designed to work in just this manner.   :P
There are still some little discrepancies between his video demonstration and the performance of my system that could be ironed out. Meanwhile, I hope to see other people building and testing. The PCB template makes it very easy (it's even "actual size") and the parts are really cheap.
With enough other people building, maybe someone will discover the right combination to make a true "self runner"... and maybe pigs with wings can actually fly, too.   ;)
TK,  here my replication,  first power up shows leds brightly on, but they turn of after removing the 9V battery, guess i need some "tuning"
I have some more turns as that was the length of the Litz wire a had (don't want to cut it up), but tried to keep the prim/sec relationship.
I use a diac (only one i found in my junk box) as D1 (like suggested by lost_bro), can change to any diode.
C1/C2 are 220pf, 100pF, 10pF parallel.
Screenshot shows
TP1 (yellow) (referenced to ground)
TP2  (Blue) junction diac/anode Led3  (referenced to ground)
Regards Itsu
Grumage
Quote from: ramset on April 05, 2015, 02:19:02 PM
reminds me of an old joke, and the punch line [spoken with a Kentucky drawl]
is "well Son ..You can't get there from here"..
sorta just as silly as assuming we will never figure out how to get that power over our heads to
do useful work here on the ground...
I was speaking with Grumage a bit ago about this atmospheric harvesting ,he mentioned his wire that
pulled energy from the air ,Tommey Reed also mentioned a similar system [low power tho 6-8V]
well Grum started talking about a fellow that was using Zinc and horseshoe magnets to harvest from the atmosphere ,he was a prisoner at the time ,and they let him out to work on his invention.
which he did...[patented in 1914 I think??]
the conversation progressed to a point where Grum mentioned another man that had taken this device to a 96 watts ??[I think} with a similar  zinc and magnets array a few feet square ??.
at ground level.
I am absolutely convinced that we can harvest MUCH more from this Lightning strike potential
which exists all over the planet...
we can definitely "get there from here"
Chet K
Dear Chet.
It's been a while since I last visited this thread  !!  :)
Roy Meyer's Aerial Device.
Roy Meyers was granted UK Patent 1913,01098 in January 1914.
http://www.energeticforum.com/renewable-energy/10947-jes-ascanius-radiant-collector.html
Both these devices are well covered in Patrick Kelly's latest updated book Chapter 7 page 8 onward.
Cheers Grum.
