Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Grumage
Quote from: adriangray on March 28, 2014, 03:47:21 PM
If you go to google translate and pull down the Russian key pad and copy the data in it will say some thing like one turn but not shorted out ;)
Dear adriangray.
Welcome to OU.com.  :)
Luckily for us we have a number of fluent interpreters here, but thank you for your observation.
I have attached a drawing of the load current that is always present traveling through L1 on it's way to the LED's. My reason for this is to point out that the transformer is not being used in a conventional   way. There will be a constant flux in the core which will increase with the operation of the Mosfet switch at a frequency yet to be determined.
Study and ponder !! Comments, most welcome.
Cheers Grum.
adriangray
Hello every one I was initially wondering if any one had got any of the energy saving devices working, the Akula (shark), device, I have heard talk of a magic transformer, but I don't see any evidence of that at all, as that only happens at resonance, as I found as a kid when I use to get my DRX1 crystal set to bang out radio Luxemburg at full blast down my head phones ;) by winding a weird transformer extra winding round the rf coil and feeding it back in.One thing I do notice is Mr. grumage is using a NE555 IC but it does not modify the wave form to synthesize the TI494 expected wave form, and the 494 is another kettle of fish in the way its configured in this circuit. ;) any way you need a diode to change the pulse width or it will use mega current and blow the MosFet
Grumage:
That basically is the main current path, although your red line is a bit coarse.  I am assuming that you are stating that the current flows through R5 at the end and not C5.
I don't believe anyone has discussed the "Stop" switch.  When I look at the schematic, it looks to me like the Stop switch has to be open-circuited for the circuit to run and light up the LEDs.  If that's true, then the whole circuit is just a glorified "solid state Bedini" circuit.  That's not good news because then all that you have to do then is measure the power-in and power-out.  Mother Nature will do her thing.
Dave:  Wasn't that cool?  A circuit made with water that does exactly the same thing as an electrical circuit.
Grumage
Dear MileHigh.
I agree the red line was a little coarse but in essence the current carries on to the negative rail via R5.
My interpretation of the stop switch is exactly that, a stop switch. If we have a "magical" transformer action then that is our replenishing path. Obviously this will become apparent, or not, once we have a complete prototype.
Dear adriangray.
The schematic you are referring to was a suggestion made by one of our members T-1000 with a view to a simple pulsing arrangement. See here. http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/msg394290/#msg394290
In the hope of perhaps finding anomalous transformer outputs.
The Guys over at OUR have spent a few days debugging the TL 494 and now seem to have a handle on it's operation. Please take a visit !!
Cheers Grum.
adriangray
Hi and thanks for the welcome greeting,
If  I can transfer some of my observations I have picked up through the years, I only hope that this might be of help, I'm no Russian scientist or guru but I have seen on some of the sites observations where the narrower the on pulse with the largest fly back ringing time in the, and a tuned (resonantly) tuned transformer the better the energy transferred, and most if not all appear to tune the tank output coil tuned to three times the fundamental (original) energy frequency so that it is phase locked also to the original and as the ringing almost stops, the wave form starts again.I would guess you would need a degree in this type of work to successfully excel in this field to produce a working device, like Eric  perhaps./
