Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 122 Guests are viewing this topic.
4Tesla
MenofFather
Quote from: 4Tesla on April 13, 2014, 09:09:14 PM
I guess this schematic has some info on similar transformer.. but 1:1:1?  Maybe someone can translate?
Yes, all coils have same number of turns.
scratchrobot
Looks like this is the same device also powering 2 bright LED's
https://www.youtube.com/watch?v=PoGfSDbnwbk
Discription from semenihin-77 posted last year:
Who can correctly translate into English , do it! :)
Those who do not want to spark, those who look for sverhedenitsu simple , for those who want a simple and intuitive device is the invention Andrei Melnichenko , who is also I think the author of the roller. Circuit analysis was conducted on Realstranike , many experiences delivered by me . Now I can show the scheme and the principle which underlies the work. Work still in progress , you can continue with them . Element base simple.
And so how this LED flashlight.
The circuit consists of DC boost converter , which converts the primary power supply 3 to 4 volts at 6-7 to power two LED base circuit patent Melnichenko - transgenerator . This is based on the split core is magnetized by means OEDS . Who are interested can read his many patents and video.
DC converter makes two right - of -first converts and increases the voltage to power LEDs, and magnetizes detached armored core , due to this energy is produced , which is removed from the core and the armor is used to power the circuit . Since this energy to properly dispose of used chip logic , it is an active load for the free energy , this energy output is regulated by a very simple and ingenious is LEDs , coarse and fine adjustment by changing their blink rate achieve the desired load . Is there another fuse circuit in the form of the FET , which is connected to the inverted output k561LN2 as soon as the voltage reaches 5 volts, it closes the power through a resistor , preventing thereby greatly change the input voltage to the regulator . I enclose a diagram and a video that shows what is happening in an armored core , remind him winding sections, the first winding needed for DC converter , the second for feeding the entire device.
http://www.hyiq.org/Downloads/Andrei_Melnichenko_Inventions.pdf
http://www.ferromagnetic-energy.ru/core_of_the_physical_effect/
magpwr
Quote from: MenofFather on April 14, 2014, 04:37:25 AM
In this circuit 510 is nanofarads or picofards?
http://www.overunity.com/14378/akula0083-30-watt-self-running-generator/dlattach/attach/136666/
Hi MenoFather,
Similar to value in MC34063 datasheet it's 510pf.
The objective is to syn 2 signal from 2 I/C together to get it right.
The video 1 of the device which i am interested in somewhat reveal how the waveform should look like else failure would be the result.
Stick with this circuit provided by the circuit creator and just ignore all the rest of the unknown/non validated schematics provided by others.Since they don't know if that unknown circuit provided by their findings works in the first place. :D
My mind is simple if you can get <1watt free energy device working then we would eventually know how to scale up to a higher power output to share with the world.Akula name will slowly fade away from our minds in the near future although he gave us inspiration indirectly."This is what anyone whom hate free energy need to fear"
At point please save valid circuit diagrams ,start experimenting(For those with oscilloscope) and replicate.
Good Luck as anything unexpected can happen from here.
