Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 28 Guests are viewing this topic.
MenofFather
Я по ошибке купил hcf4049ube, продавсу сказал CD4049, но он мне дал такую и у неё 8 ножек, она не подойдёт?
HCF4049UBE is not good for this project?
verpies
Quote from: scratchrobot on April 14, 2014, 05:01:44 AM
Looks like this is the same device also powering 2 bright LED's
https://www.youtube.com/watch?v=PoGfSDbnwbk
Similar.
This circuit has 4 LEDs, the hex inverter is fully utilized and the MOSFET is doing almost nothing.
magpwr
Quote from: MenofFather on April 14, 2014, 07:24:35 AM
hi menofather,
I am merely using whatever I/C i have available HCF4069 or CD4069 or even MM74C04 should produce similar results.
My led blinking test was using existing available IC HCF4069
http://www.fairchildsemi.com/ds/MM/MM74C04.pdf
MenofFather
I reconect conections and made on HCF4069. And can change frenquency from about 1 herc to about 200 or maybe more. I see on oscilioscope and see wery short impulses let say of 4 herc. And divice vibrating on that frenquency. I not understant that do 34063? That it frenquency? I use one and other coil same lenght and not get selfrunning, LED green also blinking of 1-200 herc, that I ajust.
magpwr
Quote from: MenofFather on April 14, 2014, 09:33:21 AM
hi MenoFather,
For the time being i'm not able to advise anything since i did not received required components to start assembly in order to advise others.This is my first time working with MC30463. ???
If anyone have completed assembly please advise outcome once it is calibrated using oscilloscope.
