Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
NickZ
  I will soon be showing how the output of my Mazilli circuit along with a yoke core can be improved substantially by the use of magnetite magnets added to the core. The trick to this type of tuning is finding the exact right position of the magnets, to obtain improved performance.
  So, yes the cores are important, but their normal output can also be improved to possibly be more similar to the special Russian type of yokes as well as other types of cores.
  Although I find that the louder the devices rings, the higher the output power it has. But, depending on core tuning, at times the output can also be high, without any audible ringing.
I know that this may have little to do with the circuit that you are working on, but I thought that this information may also help here. Give it a try, as costs very little to do this experiment.
  I will upload a video showing this in a day or two. I am a bit busy right now with Easter Holidays, and all.
MenofFather
Quote from: T-1000 on April 16, 2014, 07:26:38 AM
I disagree, the core materials used are most important if we are talking about NMR effect there. Otherwise what makes additional source of energy there for self run and powering small load?
Cheers!
Ok, why then other use needed cores and not get selfrunning? Kodėl tada kiti naudoja reikiamas šerdis ir vistiek negauna, kad save maitintų generatorius? Matyt, todėl, kad čia ne šerdis yra esmė. O energija gali būti gaunama iš supančios aplinkos, yra šaldoma aplinka ir gaunama energija, bet šaldama ne įprastu šalčiu, o kitu būdu. :D
Hope
I agree that the tuning of this device and all using this principle is a manipulation of the bloch wall.  Nice to see it so clearly in Wesley's translation.  By using this principle a small deviation of the wall magnifies the overall electrical energy.  In essence this is showing proof that energy is not dependent on electron movement, it is magnetics movement that matters.
Alignment of fields allows one movement of bloch wall to directly  magnify in effect of the electrical energy (Excite).  Not what we are taught about electrical energy in science back at DeVry.   This is knowledge that is finally correct and this we can surely build on.
Feedback that enhances the movement of the bloch wall will cause runaway energy to build (self run and beyond).
Hope
Reminds me of using leverage to gain mechanical advantage.  Looks like all matter micro and macro works the same.  Magnetics is where the magic happens.  It turns out that it is science and not magic after all.  Just science not understood fully or applied correctly until we learn how.
NickZ
  quote from T-1000:
        end quote.
   IF we are NOT talking about NMR, but of an additional natural and safe energy effect caused by the Aether, some of you may be looking in the wrong place.  Unless you like poisonous mostly unnatural man made sources due to nuclear decay to play around with, and to have around you and your families at all times.
   To create energy from the nuclear decay and dissolution of matter,  is not the only way to go towards our goal of free energy devices.  Nor will these types of devices possibly ever be legal, safe, nor allowed.
   Tesla mentioned that All nuclear or radioactive forces or effects are caused by external sources to the corporal materials used. And that it is this illusive Aether that is where all energy comes from. If there was no Aether, nor the everywhere existent Vortex force, there would be nothing holding any atomic substances from dissolution back to the source where they came from.
  Believe it not, that is your choice.  But, the Earths magnetic resonant devices are enough for me to work on and develop. When I hear talk about NMR, well, it sort of makes me sick, sorry. And to bend Kapanadzes explanation and working ideas, as well as Akulas and other inventors thoughts of their devices to fit this end, also makes me wonder, why anyone would want to go that route.
