Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
Look again.
In the first place, the "AS" data sheet that I attached shows something DIFFERENT: A different dimension and a mirror-image pinout. The NUMBERS of the pins are different. The LOCATION of the pins is the same: the MAINS INPUT is next to the case wall and the DC OUTPUT is more central and is next to the gap containing the potentiometer and the LED ! This is actually an industry standard arrangement.
4Tesla
I just posted the pinout.. didn't you see?
AS = pin 1&2 DC
RS = pin 1&2 AC
Akula using a AS supply
OOOPS...... think about THIS photo, at 15:59.
Why/how is the GREEN LED on?
The black wires aren't connected.....
If the BLACK wires are the output of the PSU that is supposed to be running the board that is supposed to be powering the White Wires that are supposed to be powering the PSU..... then the BOARD is running without the necessary feed from the PSU.... which he showed didn't work in an earlier shot.
If the BLACK wires are the mains input to the PSU..... but they are disconnected..... then how is the Green Power LED still on?
Quote from: 4Tesla on April 21, 2014, 02:46:58 AM
AS = pin 1&2 DC
RS = pin 1&2 AC
What is the matter with you? Can you not read?
4Tesla
I think there was a point where he was running circuit off 9v battery?  I'll have to look at the video.  If not.. yep busted.  So you saying the datasheet isn't correct and that AC is always on the outside of the supply.. could be.
