Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
0 Members and 127 Guests are viewing this topic.
EMJunkie
Quote from: avalon on April 22, 2014, 03:56:28 PM
I just listen to a recording of a Teamspeak session on a Russian forum (Zaryad). While I still get an impression that Roman doesn't fully understand the processes behind his circuits, he can, indeed,  make them run in a self-sustained mode.
Hey Avalon,
Any chance of posting the link, or even better the file for all to use as a resource?
All the Best
  Chris
r2
Hey Avalon !
" 4. Lifetime of his devices is limited due to some kind of deterioration of ferrite cores. (They also heating up when units are operational)."
Years ago we ran a few test at the university with different kinds of ferrite cores and after 1 month most of them just became like empty. A piece of garbage.... Do you know why ? At certain frequency and resonance the ferrite lost mass slowly...delivering radiation. YES. RADIATION. RADIATION...READ AGAIN...RADIATION !!!!
MnaZn(1-a)Fe2O4 // NiaZn(1-a)Fe2O4) + copper = BAD FRIENDS
If you people keep playing with this, you probably will pick a BIG CANCER !!!. There is no OU...the ferrite is just the fuel and the electronics is the magic spark !!!!
Just use another core types (air or laminated Fe). Please just be careful with technology that you don't know 100%.
EMJunkie
Quote from: T-1000 on April 22, 2014, 03:11:42 PM
Some food for thought - what things you will observe on bulb and on hard type(magnetic) ferrite magnetic/electric configuration when having bucking coil arrangement like this?
Hint - this arrangement can be observed in latest akula videos.
Hi T-1000,
This is of course the smartest observation I have seen on this thread to date! Excellent Post! It may be the case that the Coils may not be 100% correct compared to the drawing but they are very close.
All the best
  Chris
EMJunkie
Hi All,
I am going to go a little further, seems some are interested!
Lurkers, please join in too!
The A Vector Potential and the Magnetic Field - A and Phi
See below Picture for illustratory purposes. See here for more information.
Note: Arrows pointing to the Right indicate the Right Hand Rule as applied to the magnetic Field. Arrows Up and Down indicate the Bloch Wall Growing as a result of Time moving away from t=0. This will reverse as Field Maximum has been reached and Field decays as a result of IR Factors.
I am going to take you on a ride in my Quantum Automobile! Plenty of room for all!
Imagine the typical Solenoid, or Coil of Wire, Imagine the dynamic changes that occurs to each area at specific times throughout its operation. We are going assume a 50Hz 50% Duty Cycle, typical AC Sine wave on the Input. We are going to park our Quantum Auto in the middle of the Core, absolute centre, where the Bloch wall will grow and decay with progression of the IR factor resulting in the Magnetic Field that changes in strength over time.
An observation can be made and the result is quite astounding!
Observations
At t=0 we see nothing but particles and depending on the core material we may see residual Magnetic effects. Currently we are not too concerned about the residual magnetic Effects. As time moves from Zero we see an amazing effect!
Looking up we can see an growing Toriodal Shaped Electric Field with Spin in the Clock Wise Direction moving away from us from our Observation Point.
Looking down we can see an growing Toriodal Shaped Electric Field with Spin in the Counter Clock Wise Direction moving away from us from our Observation Point.
Each Growing in intensity and at the same time moving away from us as the distance of the Bloch Wall grows in time.
Now we move our Quantum Auto and move it out to the perimeter looking sideways at the same Coil. What do we see now?
The point of this Exercise!
At this stage it is obvious that we have a difference in effects from our observation point. From outside we see two Toroidal electric fields that permeate all space growing and moving away from each other with Equivalent Spin Direction in what appears to be the same direction! From the Stand Point when we parked our Quantum Auto at the Centre of the Bloch Wall, we saw the opposite, Non Equivalent Spin Directions on each Toroidal Electric Field and each Toroidal Field moving away from each other.
The point here is that Placement of coils is important, what a Coil sees as a result of its placement can change the entire operation of the device. Not only the placement but also the direction of turns is important if it is placed on the same core as the input coil. Turn Direction is the difference between a Dead Short in the device and not shorting the device and accessing another effect that some may not have seen before.
Experimental Results
I just want to say, the above is all from experimental results. Its not all conventional and to some, it is absolute blasphemy! But its tried tested and true. If you wish I can share experiments to prove what I have said is true.
All the Best
  Chris
a.king21
The principle of operation of the Akula device is a new type of LENR.
Unlike the Rossi system (which produces heat which is turned into electricity)
Akula produces electricity directly by consuming the ferrite core.
