Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
EMJunkie
Quote from: a.king21 on April 22, 2014, 08:31:36 PM
The principle of operation of the Akula device is a new type of LENR.
Unlike the Rossi system (which produces heat which is turned into electricity)
Akula produces electricity directly by consuming the ferrite core.
Please correct me if I am wrong, but not all Akula's devices use ferrite cores, some are air cored aren't they?
All the best
  Chris
r2
consuming the ferrite core =  radiation
There is better stuff from Akula to play with it....
PEOPLE, BELIEVE ME, CONSUMING FERRITE = RADIATION =  CANCER
EMJunkie
Hi All,
A Little more Information. A Video posted from 'Andrea Bianchi' shows exactly what I have been talking about.
Video One: Akula0083 Lantern 3 disassembled 1-2
Video Two: Akula0083 Lantern 3 disassembled 2-2
I have Flipped and modified one of the pictures below to further explain what I have been talking about. Each Secondary Coil is configured to Buck the other Secondary Coil. I have put a white line down the middle to show what I have been talking about.
I have taken apart the Picture and joined as if the coil was on one single solid core.
If you want to see a demonstration of this effect, see my Video here: A Vector potential and what can be achieved once understood.
This is a very important bit of information in the puzzle.
All the Best
  Chris
P.S: This is an old document now but I have detailed some information here: Self Assisted A Vector Potential Oscillation
Being this is an old document some information may not be entirely correct and or may be incomplete. The general ideas are still there and some information may elaborate on what I have explained previously.
Hope all this helps!
Dave45
Would you like to see the A vector field  :)
The first pic ac
second dc
EMJunkie
Hi All,
This is my last bit of information. It took m a long time to understand this bit and I am now going to share. You do with it what you will.
Your input Coil can have very little turns.
Your output coils can have many more turns.
This works as a Step UP Transformer
Turns on the output determine the output voltage only, not necessarily the output Current. There is NO or next to NO Lenz Law in this transformer. Like I have explained earlier its not Conventional.
Notice Floyd Sweet had exactly 5 times more turns on his Output Coils than he did on his Input (FB) Coils and notice the FB and Input coils were non inductive from each set of coils to the other.
Good Luck Guys!
Takes a little tuning to get the best result like I said so stick with it.
