Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
EMJunkie
Quote from: havuhung on May 09, 2014, 12:03:31 AM
Hi All, Hi EMJunkie
Very good job of analyzing circuits.
Now comes the selection of the ferrite core, ferrite core of the flyback from television and computer monitor, I found that they contained materials are not the same! . .
Hey Havuhung,
Thanks!
I am convinced (100%) that the ferrite is not the key to success.
Its just a part of the circuit. Look at the success of Avalon over in the 3v OU Flashlight thread. -->See Here<--
5ma @ 2.6 volts = 0.013 mWatts
Akula has many other devices that don't use a Ferrite Core.
All the Best
  Chris
EMJunkie
Quote from: d3x0r on May 09, 2014, 01:48:50 AM
Dual TL494; now see that's easy :)
the lower one's an or gate; or 2x pulses
probably set for short pulses
I assume the bottom one is intended to be a higher frequency that the top... it drives the lower inductance also...
The main flow must happen through the pickup coil and 3 diodes... so it's not nessecarilly keeping positive, but forcing the ground side low....
reds are the 'hot sides' of caps, current flows towards them (if current flows away from them, they become hotter)
the 1000 uf near the power input (batter jump) and the 2200uf at the three diodes are in parallel actually... (with a switch between them, but the switch also breaks the 3 diode rectifier)
I guess what drives the current flow at the top is the forward emf of the 13(?) wind coil at top...
which with decreasing current could hopefully make the pickup coil create a flow in the proper direction...
(sorry to scribble all over it)
The bottom left; there's a 'Q2' I think with a 'g5%' .. is that 95?  85?  I'm guessing 9...
@d3x0r, I agree, this is how I see it working.
All the Best
  Chris
JohnnBlade
Hi All,
For the ones who have not seen it yet i added some new info and have build the circuit, so testing can be done.
http://www.overunity.com/14610/akula0083-light-no3-dual-tl494/
Greets JB
magpwr
Quote from: EMJunkie on May 09, 2014, 01:54:33 AM
Hey Havuhung,
Thanks!
All the Best
  Chris
hi EMJunkie,
If you take a close look at his video,the one with 2 tesla coil as well.The catalyst is the yoke core.He is looking at properties of ferrite from sub-molecular level level which eventually evolve to those devices.
We will be going into that at the later stage(Not as deep as molecular) to  once many of us have figured out how to unlock the ferrite to release access energy.Let us take it step by step,science didn't just appear in 1 day although it did slowly evolve from alchemy.Remember we had no clue months back and the population of naysayer was higher back then. :D
EMJunkie
Quote from: magpwr on May 09, 2014, 05:19:21 AM
hi EMJunkie,
@Magpwr, @All
I disagree! Akula's TPU Style Self Running Devices, had no Ferrite in the devices at all.
See:
These devices had NO Ferrite Core!
1: -->Akula 1 Watt TPU<--
2: -->Akula TPU Version 2<--
Ferrite Cores can vary dramatically in their Permeability even though the size of the core may not vary! Also the optimum operating frequency of the ferrite core can be quite different from one core to the other. Some may like to operate in the 100KHz range, some may like to operate in the 10KHz range, others may be in the MHz range. (Not so common in MHz, Air Cored Inductors are more commonly incorporated at these frequencies)
Why is it there has to be some amazing 'MAGIC' going on in these devices? Its not MAGIC! Its a few simple components that a smart bloke has put together. Akula may like a high Permeability or a certain Optimum Operating Frequency, its not powering the whole System! Its a part of the system. Look at only the Facts! Two Self Running Units didn't have Ferrite Cores! This fact tells me that the 'MAGIC' is not in the Ferrite Core.
Sorry to ramble but people making wild unsubstantiated claims about 'MAGIC' does not make any progress!
All the Best
  Chris
These Self Running Devices had NO Ferrite Core!
