Motor Generators - Free Energy - An Explanation
Started by e2matrix, March 10, 2014, 02:06:29 PM
From                      ic-motor/e-generator efficiency optimizing
                     http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=19809971&OPS=ops.epo.org&SRCLANG=de&TRGLANG=en
     ic-motor+gear/transmission/differential and e-motor/differential comparison
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=2792258&OPS=ops.epo.org&SRCLANG=fr&TRGLANG=en
                                    the essential from the link above :
The output torque  at the shaft 25 minute at 6000 rpm, is the same as the output torque of the internal moving device, inert wheel.
This device has four engines 500 wats or wats in 2000, with electronic management is likely the same performance power and torque a motor
heat 50 hp, while ensuring ancillary services including heating and preheating véhicule.5 The average consumption is about IOOO wats hour.
                                                   ergo:
     2000 Watt (4X 500W) motors  instead 50 hp internal combustion engine
                     ( austinev.org link: 15 hp ic-engine ~ 1 KW electrical  ???  )
                              this explains the Livenich-principle
          optimizing the e-motor : reactive circuit   like Dr.Imris
                                                finally:
       the best Nm/KW performance  for the ideal  e-motor/e-generator-coupling
                                  and realizing,that has been done.
woopy
Hi all
Thank's for the incouraging comments
Yes this is very interesting to play with this device, running in my hands , and i try to understand and to get the feeling of the beast.
I have read some of Kanerev theory but the translation from russian to english is not very easy to understand.
Kanarev, in his papers,  is clearly contradicting the "old "  Newton's law, by adding the fact that the "inertial " force stays arround an object travelling in a a stable path.
And if i have correctly understood the theory , this inertial force could  be reused in the deceleration ???
Has somebody already checked the work of Kanarev ?
thank's
Laurent
Here,a google-translated- 1972-publication -pdf from a german inventor ,Otto Stein :
http://translate.google.de/translate?sl=de&tl=en&js=n&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwolfganghann.fruchtesser.de%2Fzukunft.pdf
original paperbook-copy : http://wolfganghann.fruchtesser.de/zukunft.pdf
Sincerely
              OCWL
1.from the #10 Walge-publication:
However, the possibility of the new know-how is also for use so-called
Wind power, or hydro power generation facilities.
2.There is a Linevich-figure,where instead an electric motor a windrotor is coupled to the gear mechanism :
http://worldwide.espacenet.com/publicationDetails/mosaics?CC=DE&NR=102012002418A1&KC=A1&FT=D&ND=3&date=20130814&DB=EPODOC&locale=en_EP
3.The Biot-Savart accelerating force formula:
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3330899&OPS=ops.epo.org&SRCLANG=de&TRGLANG=en
The invention is based on the realization that there is an analogy between electrical engineering and fluid mechanics.
This is that an electromagnetic field around an arbitrarily curved wire-like head and a flow field around a arbitrarily shaped vortex thread are described by the same law, the Biot-Savart law.
The variables "increase in magnetic field strength" and "speed increase" correspond to one another.
Since magnetic field strength can be concentrated by by winding a current-carrying conductor in a coil, you can achieve a speed increase in the flow technology by winding a vortex filament into a coil.
4.A wind (electrical:-ing) force accelerating chamber: http://home.earthlink.net/~fradella/RPMgenerator.htm
5.Squirl/Whirl-Wind chamber technolgy development and exploration trial :
Olaf + Juergen Schatz ("windhamster" : a flop ! a desaster !)
http://worldwide.espacenet.com/searchResults?compact=false&ST=advanced&locale=en_EP&DB=EPODOC&PA=juergen+schatz
                                                  title ?
http://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021227&CC=WO&NR=02102838A2&KC=A2
It is all about thermo= motion dynamics, included compression and expansion
chamber~turbine~ transformer/concentrator/gear : turbo-netic
                                http://en.wikipedia.org/wiki/Vortex_tube
               Biot-Savart Formula coil ( gyula :Klinsing !) = Tesla coil ?
DreamThinkBuild
Hi Laurent,
Really nice build. Thanks for sharing.
Here are some ideas to maybe capture the oscillation set-up by the spinning weights. Have a plate with arms that extend outwards attached to the bottom where you have the pulley then either place magnets with fixed coils or lever arms to crank a DC motor shaft back and forth.
Now there is one part I do not understand is neutralizing the negative impulses. He says he adds a "outrun muff" I don't know what this means after looking all over the net. Maybe it is a one way bearing like you use. If that is so then instead of an oscillating plate mount it to a one way bearing through the central shaft. As the shaft twists the outer plate will start spinning due to the force of the positive impulse in one direction and will coast/slip on negative impulses, picking up speed on each impulse. This wouldn't really change the magnet arrangement but would void the DC arm driven version.
If the gears diameters with the weight were increased this would set-up a really strong oscillation. This looks like something to test further.
I attached some pictures to make the ideas clearer, maybe inspire someone with a different idea.
woopy
Hi DTB
Thank's for your generator proposal, but i think that Linevitch system is based totally on the transformation of the oscillation in a unidirectional movement due to the one way bearing.
So it appears to me that if you try to use the oscillation in direct, you will have no gain and only losses.
As i show on my video, if the system is hanging on the wires , there is a lot of oscillations, and absolutely no torque at all. Because the complete system is in equilibrium.
So you need to capture the inertial energy by an imbalance  mean. And this mean is the one way bearing (and it must be of very good quality in order to stop and go at the very smallest movement of the shaft).
The better the one way bearing , the better the efficiency of the system.
But i may be wrong
Just for tonight
Good luck at all
Laurent
