Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
The "A" vector in this schematic is in the center of the toroid poles along the axis of symmetry. The schematic makes it clear that the "A" vector is the portion of the magnetic field that is PROJECTING AWAY from the source!
synchro1
Two Shumman schematics: This is the THIRD FLAGSTONE of the Jerry Bayles theory!
synchro1
Please have a look at this video entitled the Macroscopic Aharonov Bohm experiment-The neutral zone in the middle of the magnet+
http://www.youtube.com/watch?v=ugxmtT4FUME
Quote from YouTube,
"The Aharonov--Bohm effect is a phenomenon in which an electrically charged particle is affected in a region in which both the magnetic field B and electric field E are zero. Simply speaking, when an electron beam passes around the middle of a long solenoid, the beam is strangely deviated and the interference pattern on the screen slides. As there is not classical force exerted on the electrons, this effect has been commonly considered as quantum mechanical".
We see the current carrying bar both attracted and repeled by the neutral zone between the bar magnet!
The "A" vector axis of symmetry and the neutral zone between the bar magnet are identical. The Chiral homoplar disks are projecting a neutral zone called the "A" vector.
The Jerry Bayles balance magnets begin to wobble at Shumman resonance of 7.83 hrz. The neutral zone projection may receive some oscillation reinforcement from the atmospheric Shumman resonance cavity at that spin frequency!
synchro1
I feel this video is relevant to the Jerry Bales 90 degree wobbulation effect, because we can see the rotor in this video turn while at 90 degrees to the bar magnet neutral zone, but it's motionless while in line with it. This demonstrates that the "A" vector neutral zone of Bayles's chiral disks and balance magnets is on the vertical axis. This makes sense because there's a bipolar EMF potential building on the side surface of each spinning disk, as demonstrated by Diveflyfish in his video.
http://www.youtube.com/user/gtxfrance/videos
synchro1
"You might be wondering what in the world is a scalar wave! It's actually pretty simple. Unlike a transverse wave (like an ordinary radio or light wave) a scalar wave's amplitude does not fluctuate up and down. Instead, try to visualize it more like a vibration of electric potential expanding and contracting in the direction of propagation.
Scalar waves are also often called "Tesla Waves" or "Longitudinal Waves." All of these terms refer to the same type of wave which oscillates in the direction of propagation instead of perpendicular to the direction of movement. These waves have many unique properties which have been tested and confirmed repeatedly".
The "A" vector is a shaped like a disk. The electric potential that Jerry Bayles says spirals outward from the spinning Chiral homoplar disks is expanding and contracting in the direction of propagation. Jerry calls them "Gravity Waves".
                                                      "A' VECTOR SCALER POTENTIAL!
