Jerry Bayles Chiral Effect Homopolar "A" Vector Alternator, and Syncho Coil.
Started by synchro1, March 13, 2014, 10:51:46 AM
synchro1
@Milehigh,
Look, I'm willing to cut you some slack, because as one can see from the schematic, diametric is through the diameter, and radial between the perimeter and the center hole. However, Jerry Bayles's chiral disks are axial polarized or through the thickness. Verpies ridiculed me for correcting you without even viewing the Bayles video. It's important we're on the same page here. Jerry has some extremely important test results to examine.
synchro1
Comment from Gravityblock:
"In Fig. 3 & Fig. 4 below, taken from a publication titled "Successful Brushless A.C. Power Extraction From The Faraday Acyclic Generator", by Jerry E. Bayles, two identical small magnets mounted on a rotor free to move on a low friction point of balance is brought to the sides of the disks and if placed on the near side (fig. 3), the balanced magnet indicator lines up parallel to the axis of the disks. If however the balanced indicator magnets are placed on the far opposite side (fig. 4), the balance magnetsline up towards the axis and between the disks! Since the disks are uniformly magnetized and uniform radially from the axis, this is most unexpected. If the disks are slowly moved in rotation, the same results are obtained. Is there a standing wave fixed around the magnets?  Here's a video of the above test.  Please note the difference in how the magnet indicator lines up at the starting position and at 1800 from the starting position.  Also, the video shows a macroscopic version of a quantum effect where the electron must revolve twice to turn itself around once. Hence the so-called spin 1/2.
A resonance at 2pi Hz and 8.00 Hz occurs during testing. At the 2pi Hz resonance, the entire test bed vibrates and at 8.00 Hz, the balance magnets in figures 3 and 4 swing back and forth violently. The meter also vibrates and seems to follow the action of the balance magnets. Further, the static alignment of the balance magnets remain relatively still as shown if the disks are rotated slowly by hand. Due to the alignments being 90 degrees out from one side of the disks to the other, it is postulated that there is some sort of active standing quarter wave across the disks even when they are not being rotated. Further, it is locked into an geographical North-South alignment for this setup. The North-South alignment may not be more than coincidence but the standing wave is locked into the above alignment. When the magnet disks are spun, the standing wave is force to degenerate and radiate (this is proof that the rotation of the magnet is relevant). This radiated field power has been measured and the results are encouraging. This means that no contacts are needed on the Faraday disk to extract power under the above setup conditions.  Further tests reveal that free from any contacts, the near side balance test oscillates the test magnet balance the most at 8.3 Hz and the far side position oscillates at 6.28 Hz. Also, at 6.28 Hz, the entire support for the magnet disk rotors and drill motor is observed to shake vigorously with a sharp resonance point at 6.28 Hz".
synchro1
Look at this video of Jerry's Faraday Power Generator:
http://www.youtube.com/user/JEBAYLES
Jerry says:
"The surface of the magnets are covered with alternate layers of copper and nickel by the manufacture. The surface moves with the magnet as a result".
synchro1
Topic: Unipolar Induction - Relative motion isn't needed!
Ther're just a few qutes from Gravityblock at the end of this thread. There is no question about it, the neo disks are axial polarized and positioned in attraction. This is number one!
synchro1
The last part of Gravityblock's final Unipolar Induction - Relative motion isn't needed! comment about Bayles Homopolar generator: This was August 2nd 2012. Gravityblock maintained he planned to purchase two disk magnets to replicate Jerry's findings. There's been nothing since.
"In one of the tests by Bayles demonstrating the chiral nature of the left and right sides of the magnets, the magnetic balance rotates 360o when the magnet discs are being rotated.  Slight imperfections in the axially magnetized PM's rotating on their axis could never show such a huge imbalance in energy on the different sides of the magnets.  In addition to this, the resonance occurs at the Schumann frequency of 7.83 Hz on the right side and at a frequency on the left side such that the difference frequency multiplied by the circumference of the disk magnets yield a calculated least quantum velocity equal to the square root of the fine structure constant in meter per second units. Since there is uniformity in the disk magnets strength and dimensions, and another pair of identical magnets demonstrate the same chiral energy difference between the left and right sides, it is herein postulated that the gravitational field of the Earth is creating the chiral standing wave around the disk magnets. Hence the 5 Hz resonance in test 5 as demonstrated in the movie. (5 Hz is 1/2 of the 10 Hz predicted in Bayles's unified field theory) located online athttp://www.electrogravity.com
Also, the Magnetic Potential Vector (A-Vector) is proven to penetrate iron pipes with no measured loss in this A-Vector test by Bayles.  The A-Vector's ability to penetrate iron pipes with no measured loss is a good explanation in why an increase in current and voltage in the behemoth pickup coil(s) are close to equal regardless of whether the core is iron or air.  This phenomenon is due to the A-Potential, and not because there may be slight imperfections in the permanent magnets".
