Conventional current flow VS Electron current flow
Started by Dave45, March 14, 2014, 08:15:28 AM
Quote from: Dave45 on April 07, 2014, 10:07:41 PM
https://www.youtube.com/watch?v=aLu5SvgUz1I
http://makeagif.com/i/kdxfon
I really have more important work to attend to, Im wasting my time here.
Your "makeagif" site sure delivers some nice juicy p0rn popup ads!
Yep, I can tell that you have much more important work to do. Certainly you are wasting your time here... since you refuse to study, to perform actual experiments rather than demonstrations, or to carefully consider what MH and others have been telling you. You are sure that you are right, so why bother to waste your time?
But you really should try to think about why all those tiny and large inductors are sprinkled all over your computer's circuitry, and how your computer manages to operate at gigaHertz speeds, if everything that real EEs think they know about inductors and current flows in circuits is wrong.
Dave45
Yea I noticed the popups, you would think that would be censored or better yet eliminated, I used the site years ago and dont remember the trash being on there then.
I understand what your trying to point out and Im sure it works what Im trying to show is the mechanical function of the field, and as far as all the really smart EE's they use what they have been taught, just like you.
I am trying to show you there is an alternative, has your conventional view showed you how to harvest free energy, in how many years, 150 or so.
So after 150 years of paying for something that is free with no answers in sight wouldnt you think its worth a look.
Dave45
What the electron current flow shows that the conventional method doesnt is that there is a polarity change in the returned spike
pulsed with negative.........pos return
pulsed with positive ........neg return.
QuoteAs the magnetic field builds it creates amperage and as it falls it creates voltage each move in different directions through the circuit.
More like as the magnetic fields builds it is one in the same with the amperage.  It's the voltage applied across the coil that slowly overcomes the electrical inertia of the coil which results in current flow.  When the magnetic field falls it sustains the current flow and the current flowing into the load results in the generation of voltage.  So in the last example, it's really the resistor that creates the 10,000 volts.  The current is the cause and the voltage is the result for the case of a discharging inductor.
So you have a long long way to go to understand what you are observing.  Or you can keep your blinders on and do your thing while imaging that the "government is worried about Dave45 playing with his coils."
