Hydrogen Production Breakthrough
Started by markdansie, March 14, 2014, 09:23:33 AM
ramset
LancaIV
what is this tiny spinning thingy you posted
http://www.solarhydrogentrends.com
thx
Chet
Thanks Grandma
Quote from: ramset on March 14, 2014, 12:37:34 PM
LancaIV
thx
Chet
                 This is these thread-theme-object ! I think so !? ::)
       1 KWh Water-"fuel" as gasoline-equivalent  for less than 1 US$cent
      +/-  the water-"fuel" barrel(bbl)  for less than 16US$    fob home reactor
wmbr
          OCWL
Quote from: markdansie on March 14, 2014, 09:23:33 AM
If this is real its game over. However i question their claim of getting 1kg of hydrogen out of one liter of water
http://revolution-green.com/hydrogen-production-breakthrough/
Kind Regards
Mark
And so you should question it, because one liter of water weighs one kilogram, close enough.... and as Paul-R pointed out above, water is mostly oxygen (atomic weight 16, one atom per water molecule), not hydrogen (atomic weight 1, with two atoms per water molecule), with a ratio of 16:2 or 8 to 1 by weight. So either the reporting is wrong, or the claimants are wrong, or they are creating matter from nothing. What is most likely to be true, from those alternatives?
Quote from: TinselKoala on March 14, 2014, 01:15:43 PM
TinselKoala,you are wright ! But did you reed the prnews-content ?
The Impossible Becomes Possible
The hydrogen reactor actually turns 1 liter of water into 1kg of hydrogen!  While this flies in the face of today's basic science where even a 5th grader knows that 1 liter of water contains 111.11 grams of hydrogen and 888.89 grams of oxygen --nevertheless, numerous performance tests, including Airkinetics Inc., a prominent EPA-certified national emissions testing specialist, measured the output reactor at 50 ACFM with 93.1% Hydrogen content.
Solar Hydrogen Trends, Inc. stands by its performance claims and welcomes other independent performance measurements of its hydrogen reactor input/output by the media and leading industry experts.   (Download Airkinetics Inc fuel performance test results :http://www.solarhydrogentrends.com/SHT_performance%20_test.pdf.)
MarkE
Quote from: lancaIV on March 14, 2014, 01:29:06 PM
They make at least two claims of creating energy / matter:  112g becomes 1000g, 500Wh becomes 221,500Wh, etc. without offering any proof.  The one page report cover from a smog lab consisting of three samples:  two that more or less agreed and a third that was off by 75% does not convey confidence to me.
