Gravity wheel of Krstan Pejic. This device works
Started by Shokac, March 26, 2014, 04:09:05 AM
turbogt16v
there you go ,a scheme of ou ,all free of charge ...
the theory is very simple,if M1 motor one is charging the G1 generator one in pulse
and if given power is smaller than produced it is ou (not really,it is just transormer of gravity to eletricity)
memoryman
Mind91
Quote from: citfta on January 20, 2016, 07:06:43 AM
I wondered about that sound also.  I worked in industry for over 30 years as an electronic tech and I believe that sound could be a large contactor or some would call a relay that is switching the power on and off going to the motor.  One of the little controls on the control box appears to be a time delay relay which could be adjusted to pulse the contactor which would in turn give a pulsing power to the drive motor.  The idea of pulsing power to a motor and letting a flywheel maintain the speed has been around for a while.  I have worked with that idea myself and seen some interesting results but have not gotten OU yet with what I have done.
Can u share what exact results u got, where (in real life or in simulation) and what was setup (u can draw in paint for example if u do not have pic)
Only logical way for me, is to use unbalanced flywheel, or we can say pendulum: https://www.youtube.com/watch?v=61-C0x6xtL4
According to him (who posted videos) this version is even bater: https://www.youtube.com/watch?v=3hiNy9JSkrE
I do not see why u did not got good results Citfta if u were using same setup, and i also do not understand why is Krstan using balanced flywheel? When this guy had setup like Krstan but on 1 side more weight he got 30x. Krstan is using same setup but balanced flywheel and he is making free energy, but how he is making when on balanced flywheel gravity can't produce that electric energy that we call free energy?
Also one more question. I'm total noob to this, but what i know is if u let light bolt to work constantly over 1h, it will spend less electricity than if u made it pulse. If u make it pulse so it is working 2 seconds, than 2 not, it will work only 30min in 1h but it will spend more.
Is this same about motors, will pulsing via time relay spend more energy than if it constantly spins and u make machine pulse by loose connection between pulleys or any other way?
citfta
Quote from: Mind91 on January 20, 2016, 05:04:51 PM
Hi Mind91,
I did not say I didn't get good results.  I said I didn't see any OU.  But I did see much longer run times using a pulsing system.  My system was a scooter motor turning a shaft that had a Honda Civic crankshaft pulley on it for a flywheel.  Also connected to the end of the shaft I have tried a few different types of home built generators.   The idea came from the Watson machine that was built following some ideas by John Bedini.
In my system I used a Pic micro controller to pulse the power to the motor by letting the Pic controller turn on and off some Mosfets that were connected in parallel.  I also took the output of the home built generator and used that to charge a large capacitor.  During the time the motor was not being powered by the battery I would discharge the cap back into the battery recharging the battery.  Eventually after very long run times the battery would start losing charge.  So like I said I did not see OU but I have seen run times way beyond what the battery could normally have run that motor and generator combo.
I am still working on making  a more efficient generator to get even longer run times.  And there are some other tricks to be done to extend the time even more.  My system can be combined with the 3BGS system of David Bowling to get even more time.  You can learn all about his system by going to the Energetic Forum and looking for the 3BGS thread.
Carroll
PS: I don't really see where gravity has anything to do with the systems shown in the video.  It just looks like a flywheel system to me.
ARMCORTEX
https://www.youtube.com/watch?v=aVbfreIHGrI
Free energy for all, yet he does not say nothing about his findings, how typical.
Interresting videos, perhaps related to Pejic.
