mscoffman
Hi;
What they need in reality is called a dump-load controller. This has four control levels
that will gate in the next section of dump-load resistance when the voltage goes
above the present dump-load high level preset or exit that level when the voltage goes
below the present low preset level. It acts against the OU devices own internal impedence.
A high voltage DC to AC inverter (90%->98% eff.) has a large DC input range and the dump-load controller
keeps the DC voltage within that range, wasting energy not being used in the load.
This is designed for wind/power operations where excess energy can not be utilized.
Don't have DC level power?: use a power bridge rectifier to make it. Photoflash cap. Filter Keep attaching
incandescent load lamps to the AC output side of the inverter. Please: only count
fully lit 100Watt bulbs as OU output power. Don't measure circulating power in the
OU device to count as overunity...Overunity power is in output dummy load only. Don't use
LED bulbs or CFL's without taking real wattage into account. As load bulbs come on line
the load-dump controller resistances automatically will drop away. Future designs of the
overunity device can self limit power. Working OK?...remove dummy load, reprogram the inverter
and hook it to the grid line and pump energy back toward utility generator.
:S:MarkSCoffman
memoryman
Which OU device are you referring to, mscoffman? I have yet to see one.
MarkE
Quote from: mscoffman on May 20, 2014, 05:15:44 PM
Hi;
:S:MarkSCoffman
Under some static operating conditions a static load should be identifiable that results in maximum output.  Wind turbines face highly variable source conditions so having a variable load is important.  Solar inverters all have MPP controllers for the same reason.
These guys have to contend with he very dangerous 2KV.  I personally would put the output through a step down transformer and then couple to a load through a variac.  That way the load can just be dialed in.  If the phase is fixed then a voltmeter and ammeter combination is enough to indicate relative power so that the operator can dial the variac to the maximum power point.  Step wise resistors are just a poor man's approximation for the variac.  If they aren't going to use a step-down transformer, then the resistor stack is a more practical and safe way to deal with that 2KV than trying to locate and then operate a 2KV variac.  Such a thing is likely to be quite expensive.  I don't think that even stage lighting equipment goes that high.
T-1000
Quote from: MarkE on May 20, 2014, 05:46:38 PM
Please show your replication, the 17 posts per day will not make you "expert" in this field... ;)
Angelic
(PCB)Does anybody present at these gatherings even raise their hand and mention rms or power factor.  I for one have not heard these terms in any of their videos or seen them mentioned in blog posts of others reporting back to the masses.
Let's call a cat a cat: it's a scam.  :P
(SchubertReijiMaigo)I'm more worried that kind of things will do a lot af damage in the OU community where I believe that are honest researcher out there...
In fact when I see some new-age hippy things like "HopeGirl", "One People Community", "Our mother Gaia", "Love people",
->put every new age terminology here<- , where demonstration are performed in a village in the middle of nowhere it tend to raise in my head some big red flag.  ;D
Hell, doing science is not the same things as preaching in some new age group...
The reason that you do not see any of these things is because they are more of a gathering of "like minded" supporters of Hope Moore. These groups are very supportive of each other and and Hope Girl is using this to rally support in the pretence that they are working to help those who are in need of electricity around the world. Unfortunately she is grabbing every little piece of information that comes her way and sensationalizing it in order to ramp up her following. I am sure that James is not even aware of what she is putting out there until after the fact. There is an increasingly larger number of people all over the world that will be drawn to this. Not because of its technical merits or its breaking new age technology. That is why I think that the majority of the funding is coming in from people who are spiritually snared by the Hope Girl campaign.
