0 Members and 55 Guests are viewing this topic.
isim
@Angelic
Quote from: Angelic on July 31, 2014, 07:55:41 PM
Hi TK,
First time to post a pic. Hope I did it right. Sony 1970s that I can not find any info on. Do you think it can be used as wired or just components.
May be this schema from an old TV (1974) with Triniton from SONY will give you some ideas.
http://radio-piffret.pagesperso-orange.fr/Materiels_SONY_KV1220DF.pdf
synchro1
"With an alternating current the magnetic state of affairs is never a settled one. Each time current direction reverses, so must the orientation of its associated magnetic field. The entire field collapses and rebuilds in a magnetically opposite direction".
"You find some quotes that misuse the word "collapse" for journalistic emphasis",
TinselKoala,
You're full of it! The collapse is not gradual, and furthermore, the reactive current that returns to the system is a negative value. The instant the reverse value shows above the zero line, the "Entire field collapses violently".
ariovaldo
Quote from: TinselKoala on July 31, 2014, 05:47:52 PM
I am glad you are back! What I have been demonstrating is the extraction / conversion of the "OU in VARs" that exists in resonant tank circuits, by using an inductively coupled tuned resonating receiver or Receptor circuit. This method loads the primary tank, naturally, but does not result in collapsing the resonance like a direct resistive load will do. Please check out my latest set of videos. I've shown: running a DC motor on the true output of the resonant system; attaining high voltages without the use of any inductive collapse spike collecting; and various methods of constructing Transverters and Receptors for this system. I am operating at much higher frequencies, though, but the principles will be the same. You will just need larger components to get down to your own resonant frequency range.
(grins evilly)
Thank you.
I'm catching up !
Cheers
Ariovaldo
synchro1
Gotoluc lights an LED at no cost by pulsing a bifilar toroid. The toroid has a maget attached, and the LED's connected to an inductor, with the magnet for coil core. Look at the similarities to Tinselkoala's micro QEG:
https://www.youtube.com/watch?v=cQe49jH_3lA&feature=youtu.be
This scope shot of LUC'S provide additional dimensions over TK's:
