0 Members and 54 Guests are viewing this topic.
Bob Smith
synchro1
Tinselkoala defies me to perform my own tests. I don't have his sensing equipment. Here's what he needs to do: First he needs to shop out a beat up old Gauss meter at one his yard sales on special deal.
Hook a wire up to the scope. Run A.C. current through it, then Move a permanent magnet around the wire and monitor scope activity. I can save him the time cause I already tried it. Nada!
Next, attach a Gauss meter probe to the magnet, and measure field fluctuation from the A.C. current. Now the needle moves! What's going on here? Floyd has trouble explaining this. It's the reactive magnetic field at work on the magnet! The magnet has no effect on the reactive field or the current, but the reactive magnetic field causes an effect on the permanent magnet. This is an overunity effect.
TK needs to perform this radical experiment. This is free power folks! The VTA tested out at millions of times OU!
The A.C. current wire can't see the permanent magnet, but the permanent magnet can see the A.C. current wire!
TK already uploaded a video of A.C current spinning a compass needle, so we don't need a second test. Also Tesla's A.C. induction motor in practically every home appliance makes this test overly redundant.
Farmhand
Well it seems at a glance ( could be wrong ) that I've broken the 1 kV, the 1 kW, and the 1.4 kVAR mark with my HV tank.  ;D
What does this mean ? Where is the 1 kW of real power going and where is the 400 Watts of reactive power going ?
Seems odd. Input was 14 volts and 450 mA = 6.3 Watts.
synchro1
"In the case of AC currents, the geometry or position of the magnet and the wire will determine whether it contributes what is known as impedance to the circuit and therefore decrease the amount of power to the load".
Notice that Bedini positions his bifilar input exciter coil on the perpendicular between the opposing permanent magnet fields, completely eliminating field related impedance in the VTA input coil.
The "Magnet Core Multiplier" vectors the diametric magnet solinoid core field by 90 degrees, through the side of the wire, not end to end. This perpendicular field vectoring achieves zero impedance form the PM field in the coil, like Bedini's spiral at 90 degrees. Coupled with running the bifilar at self resonant frequency, we can eliminate reactive Ohms as well, and the gain in coil voltage. That makes the output all gravy.
I think a Quadfilar wrap with a series bifilar output coil would improve the MCM "Synchro Coil".
Synchro
STOP MISREPRESENTING MY WORK.  I have asked you time and time again to STOP MISREPRESENTING MY WORK.
You have shown amply that you are stuck in some fantasy mindset involving Tesla, multiple coil windings and now Bedini, and you have a remarkable facility for ignoring experimental evidence that you don't like.
If there was some way I could prevent you from watching any of my videos I would do it. You completely IGNORE the actual messages in my videos and you add your own BOGUS interpretations and then you come on here and spew your garbage about what you think you see and what you think you  know, but it's garbage.  You continue to prove the old adage: You can lead a horse to water but you cannot make him drink. Or, in your case, think. You do nothing more than confuse the  issue, and when you start talking about BEDINI, ffs, you are even more off the mark than when you misrepresent Tesla's work. Why don't you start your OWN DAMN THREAD and talk about YOUR OWN WORK, and stop referring to me at all. Then you can misinterpret Bedini and lie about Tesla all you like, and maybe your sycophant script-kiddies will go along with you.
