0 Members and 55 Guests are viewing this topic.
Farmhand
Maybe this looks better, Bottom right is the tank traces when the fluro is in full conduction mode. The rest are the fluro scoped in the
same way just the voltage is sensed across a 0.1 Ohm resistor in series with the load to determine the current rather than the
tank, both resistors are connected to the ground reference point. Don't ask me to even estimate roughly the load power going by
the wave forms.  :-\
Just doing the sums based on the scope measurements it works out to about 11.4 Watts load power with 3.8 Watts input.
That's cop = 3.0 or three times OU. Real in to out figures. Can it be that far off ? Yay anyway. The right hand top shot shows
that the bulb was lit with HF and substantial current at 90 degrees shift between voltage and current. So no load power but
light was emitted. yay again.
Now I will definitely have to buy the good CSR's. What load resistance should I use because that is the load voltage I want
around about and some either way as well.
I should make a video for a go fund me for better equipment. I've got better evidence than the QEG mob for real OU. And with a
legit Tesla inspired "replication" too.  ;) Just need to pretty up the primary and some other stuff.
Don't forget folks that's just one side of the output tuned and used, the other side idled at minimum activity.
isim
@Farmhand
Does your oscilloscope has a function for integrate the power trace?
Otherwise, it's possible to calculate the power from your scope pictures, but it's low and time consuming because on must count the pixels between the time axes and the power blue trace!
An other possibility is to save your traces from your scope in a text file and import this file in excel (for example) to integrate and get the power.
Can you do that and publish the data?
Thank you,
Farmhand
Hi Isim, I can save different types of files from the scope CSV, WFM, and spreadsheet data as well but I might need to connect to
the computer for that. I will do it shortly. Not busy today as yet.
Will CSV do the job or do I need the text file from the computer ?
Here's a video where I performed more or less the same experiment and show stuff. I'm not making any claims because I know
the measurements are not yet as accurate as they could be. The color coding on the drawing does not match the traces as you
will have noticed, don't know what I was thinking if at all.
Theoretically for 10 Watts input the current should have remained at 0.82 A, but it didn't. Light seemed to stay the same or improve.
Video clip shows input behavior, wave forms, the Lamp and setup ect.
https://www.youtube.com/watch?v=vFOHk_0IDZg
isim
@FarmLand
CSV it's OK.
I will look your post tomorow, it's to late for me now...
Some more Canadian bacon tidbits:
https://www.facebook.com/QEGAC/timeline?ref=page_internal
From July 23rd, 2014:
Greetings fellow Qeggers!  My name is Kevin Blundell and I will be making regular posts here to update you on the latest QEG news.  Here is the first installment.
The Montreal winding machine is now completed and we will begin winding Friday.  All is in place and I would like to send out a big thank you to Daniel Cool for taking the time to build the winder for us.  He is an angel!
As well, a second core will be wound in Toronto and will be ready in two weeks time. when it is ready it will come back to Montreal to be put into the QEG there.  The two cores will be wound differently and this is being controlled by the international research group.
Sooooo... we are getting very close now.  The international research group is in charge of the build in Montreal and will be in contact during the build via Skype.
In a couple of weeks everyone is going to see more news about the QEG.  Also, three cores are being put together in Hong Kong right now... they are connected to QEG Canada.
When the time comes, I will travel to Montreal and over see the build and will video aspects of it.   As well, we will be using the transverter and other things that the international research team suggest to get us to self looping and over unity.  We are almost there and exciting times are ahead.
We are still very much in R and D mode.  The very good news is that all of the engineers agree that the QEG will work and that the answers to get it to over unity are within our grasp.  With each build we get a little closer to that goal.  Keep your fingers crossed and please send light and love to this project.  When you think on the QEG, visualize it working.  Pray and meditate on this... be positive and help bring that energy to this project please.  It will indeed help.
It's going to be a rough and disappointing ride for the Canuks!
