0 Members and 55 Guests are viewing this topic.
PCB
Quote from: ACG on October 12, 2014, 07:45:56 PM
To PCB,
If you will please, ask the be-do-ers what do they define as Resonance.  Most likely your post again will go untouched.
How many of them would basically come to the conclusion that the bulb lighting defines resonance. LOL!!!
How many of them would say its the highest point on the power curve of in to out ratio or when the inductors and capacitors are operating in harmony.
Either way non of which are worth clapping, shouting, gong banging, or money donating.  Every microcontroller, microprocessor, asic, and serial interface ic on earth has resonance.  Some in the form of phase lock looping, some with crystals, LC tanks, others with RC clocks.  And these actually do useful work as opposed to doubling as weight training equipment and door stops.
It's probably pointless to post anything on be-do as there is no conversation taking place there anymore. Just a post, mostly from Shean, every other day or two. But if you have not done so you should watch the South Africa Demo. They bring up the rpm to just above 3000 and it snaps into phase lock in the 2900 to 3000 range. At which point the light bulbs come on. I would suggest that the reason for this is the this is the peak point of parametric excitation and once current starts to flow in the LC circuit a feedback effect is created between the the stator and the rotor. At this point more input power goes directly to the output. But its a very inefficient circuit because it take perhaps 600W to 700W  to get the machine to phase lock (resonate), at which point the power need to maintain resonance falls 100W to 200W and goes to the output to light the lamps. If then you try to increase the speed the input power does directly to the output and the bulbs get brighter (by another 100W or so). I suspect they do not like doing this because the voltage in the tank circuit probably starts to climb quite a bit and they then burn out the primary coil. The tank circuit only has a storage capacity of around 2 to 4J or so. This thing in never going to be anything more than it already is, an interesting but inefficient mechanical to electrical converter. The focus of the QEGers seems to be the build process itself and reaching the point of resonance (for the group as a whole) so as as to be "one" with the other successful QEGists. There is no serious attempt to take meaningful measurements (mostly because they are not electrical engineers doing this) for example and report results back to the build community. After the build team gets to the "resonance" point there is no place to go farther and they all dissipate, hence you do not hear from them again. I assume the 70lb block of copper and iron just sits around collecting dust. I think building a QEG is really a spiritual exercise for the people involved, as they feel they are accomplishing the impossible and sticking it to the "man".
One final thought. Where Jamie etal has let everybody down is that he has singularly failed to provide any theoretical framework for what should be done next once the machine is built and resonating. This is not surprising because as TK likes to post, Jamie built this thing believing that all you have to do is to build it and it will self run. When it did not do this he revealed via action and postings from HopeGirl that he has really no engineering capacity as such, being really an engineering "artist". Clearly his attempts to harness ground current or charge in the atmosphere were a total failure. Once you have done all that what else do you do, where do you go?. I would suggest hooking up a bank and potatoes or more aptly lemons to it as a source of power.
tinman
Quote from: TinselKoala on October 13, 2014, 02:55:09 AM
But you've Got Resonance (tm)! So how can you be so frigging incompetent? ALL THAT'S NEEDED IS TO SPIN THE MACHINE UP TO RESONANCE. AT THAT POINT IT WILL RUN ITSELF. Says so right there in the FAQs and also on the last pages of the Official Plans document. So what is your major malfunction, Kevin? I say you are incompetent because you believe in this crap... and even if WERE REAL and the lying claims true.... you are STILL utterly incompetent because you cannot make it work!
(tm)-is that me :D
Well if i had of know that all you guys wanted to see was a self running motor/generator combo,i would have whiped up one for ya'll. Infact,i'll smash one up next weekend for ya's-the first self running motor/generator combo-hell,i'll even throw in an LED for good look's. For this project we will use my new found energy source-electron drag power generation-lets call it the !QEGquack ultra pack!-no resonance needed with the new electron drag generator,she's all go at any speed.
Will post it here on this thread this coming sunday-along with the other junk here that isnt worth a pinch of sh-t :o
Quote from: tinman on October 13, 2014, 08:28:22 AM
(tm)-is that me :D
But can you start it with a crank mechanism? LOL...
(the "tm" in my post was supposed to indicate "trademark", since "We've Got Resonance" seems to be the FTW QEG CICU trademark and I'd hate to be accused of infringing on their intellectual property. Wait... they have no intellectual property. So never mind..... )
8)
Quote from: PCB on October 13, 2014, 07:07:54 AM
(snip)
Oh, it's worse even than that, far worse than a simple naive belief that Thrapp's thing worked as claimed. As I pointed out at the beginning, this thing of Jamie's is a religious revelatory experience. They don't talk about it much, but in one of the recent videos Naima tells the story to the camera. She says that Noah was told by God to build an ark and save the world from the Flood, and God told Jamie to build this QEG and get it working to Save the World (from the tyranny of Big Oil, presumably.) Jamie had a dream or vision that revealed to him the missing details that he didn't get from Timmy Thrapp during the one-hour demonstration that they paid big bucks for, and now Jamie is acting, not under the orders of Valerie and Naima, but under orders from God Himself.
This does not bode well for James. Since he is doomed to fail (unless his God lets loose with a custom miracle just for him and the other QEGgers) he is also doomed to depression, fear, and physical health problems caused by spending all those cold nights in the lab, driving the machine to resonance and staring at it, shutting  it down, turning the trimcap 1/8 of a turn, driving it up again.... take measurements and observe no change..... lather rise repeat. It's a morale-killer of a program, but even Abraham couldn't turn down God's orders.
MarkE
Quote from: TinselKoala on October 13, 2014, 03:26:43 PM
He drove it to resonance.  It will drive him to madness.
