Quantum Energy Generator (QEG) Open Sourced (by HopeGirl)
Started by madddann, March 26, 2014, 09:42:27 PM
ACG
Link to a qeg fund separate from FTW.  Half way in the comments doubt begins to emerge.  As you read closer to the top the tension grows.
https://www.indiegogo.com/projects/very-soon-free-energy-your-house-help-fund-the-initial-step-today#comments
Seems at least one donator is getting the picture and requesting funds be reimbursed.
And that was a month ago! Sounds like the originator did it in good faith and is pretty disappointed to learn that there isn't any working (self running) prototype after all.
Meanwhile, can someone help me with my little power measurement problem? It seems that I have Overunity In Vars to an embarrassing degree right here on my workbench. Er, work _chair_.
Input: DC at 11.83 V and 2.70 A = 31.9 W
Output: 633 kHz sine wave, 68 V p-p and 21.6 A p-p, in phase, = 1469 W p-p, and divided by eight = 183.6 W
http://www.youtube.com/watch?v=wI2r85CeCaw
The purpose of this video is to deliberately illustrate some pitfalls in measurement, and also to show that having large VxI measurements on your output in a resonant and reactive system isn't unusual. I present it as a sort of exercise or quiz for contemplation. I assure you that there is no trickery, all is as presented in the video.
But I would like a cheeseburger, anyway.
(I know, I know, the impedance of that current monitoring resistor is likely pretty high at 630 kHz. But my ProsKit meter wouldn't measure its inductance, so I really don't know what it actually is. Anybody have any idea? It did get very hot during the demonstration. This would be the first target for 'debunk' or correction in the numbers. )
Farmhand
Nice work Tinsel, time for a funding campaign for you, sit back we'll do it all for ya.  ;) Just kidding.
But I can confirm the results you got are good but kinda normal, your setup is a lot more powerful than mine but the same effect is got.
I used a pair of small Tesla transformers with one driven by a "Armstrong oscillator" and with only a few watts input, 12 volts and about 400 mA current,
on the primary of the "transmitter" "in the tank" I was seeing about 40 volts RMS and about 5 amps of current, which made me smile
and say wow but I knew it was accumulated volts and amps, just as the contents of any tank is accumulated.
My voltage and current also appeared to be in phase but I was using a 0.1 Ohm CSR (5 Watts) and so I was not so sure of the accuracy of the
current trace.
Nice video well done.
isim
Just for fun:
http://be-do.com/index.php/en/forum/active-qeg-builders-cicus/481-the-role-of-the-exciter-circuit
"Having been part of the team who have completed the UK build of the QEG, I am now most puzzled by the role of the Exciter Circuit, or what Jamie calls the Etheric Tuning Device. This is an LC circuit with a spark gap in parallel tuned to exactly 1.3MHz, which is supposed to be a harmonic of a frequency they used to build the pyramids. The exciter coil is placed between the QEG and motor, and is supposed to 'condition' the QEG with a spark every few seconds. In fact, according to WITTS, the exciter circuit can be removed after a couple of weeks of use because the QEG core has become conditioned and no longer needs it. So, there is a mystery here - what is this Exciter Circuit, and what is it doing? Is the exciter circuit responsible for the Overunity? Will the QEG produce overunity without it? "
etc....
no more comment!
