Whoopie Verifies topic work on this model.
Started by Hope, April 08, 2014, 05:22:50 AM
woopy
Hi Tinsel
The video seems to be private
Can you make it public please
Thanks
Laurent
Hope
Thank you for your interest,  it would really be great to see even a black box video of your achievement Tinsel.
And you video as stated above is private so we can not view it yet.
Chet,  thanks for giving us your attention.   I follow your work and believe in you honest enthusiasm.
Woopy,  thank you for the inspirations.  You too ROCK!
CANGAS
Quote from: TinselKoala on April 08, 2014, 05:46:58 AM
If what you are seeing appears to violate a wellknown and much confirmed physical law, it is _extremely likely_ that you are misinterpreting what you are seeing. Without experiments to _rule out_ all possible alternative explanations.... you or anyone else has no basis for claiming even a _potential_ violation of such laws.
There is nothing "unlawful" about either the famous Laithwaite demonstration, or Woopy's little device. You are not interpreting what you are seeing correctly, and there have been no experiments performed to rule out alternative explanations.
I have an apparatus here in my lab, that mechanizes the Laithwaite performance, using a 2.5 kg brass flywheel rotor that can be raised up from horizontal to high vertical by forced precession just as the Professor shows, using just a little continuous force not in the 'up' direction but in the precession direction. The most remarkable thing about this apparatus cannot be seen in any demonstrations I have encountered elsewhere, including the Professor's. The rotor _stays_ at the extreme "up" position without any further application of force, as long as the unit is rotating in the precession direction faster than "normal". It is truly uncanny, the closest thing to real "antigravity" that I've ever seen. However it is fully predicted by careful analysis of the system using normal physics, it is just highly and amazingly unintuitive. Unfortunately I can't show you a video of that particular apparatus, but here's a video of some early work I did leading up to my present apparatus.
http://www.youtube.com/watch?v=a81hS_iCi4E
So you are establishing priority?
And what is your Theory?
Hope
Once thought of selling an idea,  nevermore.  All this is open source.  AND worth twice the price!
noonespecial
It should be mentioned that in Prof. Kanarev's version of E.I. Linevitch's design, he incorporates 2 electronically controlled clutches. Prof. Kanarev states that without these you cannot achieve overunity or violate Newton's 3rd Law.
