3v OU Flashlight
Started by 4Tesla, April 14, 2014, 02:55:28 PM
d3x0r
d3x0r
Quote from: TinselKoala on May 11, 2014, 07:30:44 PM
Please point out the differences.
akula yellow is higher;  (1 and a part divs at 5v is 7V vs mostly 3 divs at 2V is 6V )
TK blue is higher (3 divs at 1V vs  2 and a part divisions at 1V)
akula assume scope has x10 set and it means 5... ( spanning 1 division is a little more than 5V and a part divisions would be 7V... vs 3 divs at 2V or 6V in the yellow)
so it can be seen the blue reflected back to yellow in TK is a higher amplitude relatively than akula.
Edit; oh 1 and 2 aren't what I thought they were... they're closer than I originally noted had 1V and 2V backwards
EMJunkie
@TK
Can you please post Scope Shots of your C1 VE+ and VE- Rail! Voltage and Current if you could, Please.
The reason I ask is:
Typically the Magnetic Field and Current follow the Right Hand Rule but the Voltage is in the opposite direction...
Thanks
All the Best
  Chris
avalon
Quote from: TinselKoala on May 11, 2014, 02:40:54 PM
Yes, I will bet my bottom dollar (not far away now) that all the power did come from the PSU, and was stored in the capacitors until it was released through a failed component.
I can assure you that you are wrong. I now have stable 400-500V ~ under load (2 * 1W Cree) with no failed components @ 2.6V DC / 12 mA.
I am too busy studying the effect for the moment but will post something later for everyone to have a look at.
~A
avalon
Quote from: avalon on May 12, 2014, 09:07:33 PM
I am too busy studying the effect for the moment but will post something later on for everyone to have a look at.
~A
