The Bessler Wheel, mystery solved.
Started by gurangax, April 24, 2014, 02:40:13 PM
gurangax
Quote from: zoelra on May 16, 2014, 11:16:53 PM
In my design the weight lifting mechanism is a variation of the 2 stage oscillator and it does swing in the z plane (really the y-z plane where y is the vertical axis).  I use the word 2 stage oscillator because everyone is familiar with the working Milkovic 2SO.  However my variation of the 2SO is nothing like Milkovics.  Instead of swinging, you could design the mechanism so the weight just drops and does the lifting work, but then the wheel has to rotate 180 degrees so the weight resets.  I prefer swinging so the weight returns to its initial position.  You definitely have to use the z plane for the movement.  So now you know something about my design.
well even if you say this and even the basic is the same I will say it doesnt work hence why you are here. the mystery is what makes it works?
regards
zoelra
I'm not saying my design is Besslers, just that I myself have found and associated two unique properties of levers and am using them to produce a lift.  I actually found the properties with math (what everyone said is not possible) so we will see.  Just so you know I am a member of besslerwheel.com and someone there made a post about your findings and I am following what you are saying because it is similar to my work.  I wish you all the best and look forward to seeing your wheel work, but I will not give up on my design.  It is many years in the making and I truly believe it will be a runner.  As you say there are many ways to make a wheel.
gurangax
Quote from: zoelra on May 16, 2014, 11:28:33 PM
is it via pm? because i didnt see anything in there mentioning about my findings.
regards
zoelra
what do you mean by "is it via pm" ?
gurangax
Quote from: zoelra on May 16, 2014, 11:35:56 PM
did someone told you by using personal message at besslerwheel or did i missed it being posted on the forum?
