1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
Artoj
Thanks Luc
I have drawn a mechanism which matches the top config in the loop video. No more mysteries now, only the principles of translations need to be clarified, so further improvements and understanding will result from our collected effort. Also thanks Aaron for expanding the ideas and clarity of these types of devices, we can all gain from revisiting ground uncovered by all these researchers. Regards Arto.
havuhung
Quote from: gotoluc on May 30, 2014, 10:24:23 PM
Hi everyone,
I find this invention very interesting. Thanks to all for sharing.
I made a clean looped video of the top of the device to better observe the top mechanical movement. I'm quite sure it moves in a circular motion.
Hope the video upload works. If you also select loop in your media player it will keep starting over.
Luc
Hi gotoluc,
Thank you.
havuhung
ARMCORTEX
Too big, too expensive.
Better designs and higher COP can be made I have no doubt.
But I like those arms above  ;D
gotoluc
Quote from: Artoj on May 30, 2014, 11:50:19 PM
Thanks Luc
I have drawn a mechanism which matches the top config in the loop video. No more mysteries now.
Regards Arto.
Hi Artoj,
thanks for your drawings.
I believe your top mechanical drawing is correct but what comes clear is the motor shaft could be mounted directly to the center gear which should cause less pulley and belt losses. So the question is, did the inventor go though all that trouble and waste just so the electric motor could be visible for demonstration purpose?
Luc
