1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
Craigy
sorry look at 36 seconds...you can see the side to side rocking of 3 of the 4 individual cams...and if you look closely where the 3 rivets are on the beam,  one can clearly see it is rocking side to side. I suspect you think that it is rotating as the old flim gives the impression that the shaft is rotating, but that cannot be so , as the other side of the fulcrum, or fixed point as you call it is wobbling side to side in a linear fashion
Indeed below the component that you say is locking the "rood" Rod? in place there is a gap........every so often you can see the end of the rod appear and disappear becuase it is oscillating back and forth..You say the rod is locked, but it just goes through a fulcrum to oscillate in the other direction..  ( why is the lenght of the rod so long? To provide a mechanical advange or lever effect to push the  shafts off center and start the the machine.... You don't think that rotary force is all being provided by that small motor do you?"
there is only a linear input.. infact if it were rotary it would be in the same frame of reference and would be entirely standard physics and not be anything special...It is the decoupling of systems that provide a possible route to success
this is a simple drawing i drew for my own reference,
Any concepts or ideas expressed in this post are intended for the public domain. Free licence is given to reproduce and or modify provided it is for non-profit use. I don't want money, I want overunity!!
gotoluc
Quote from: havuhung on June 09, 2014, 10:42:30 PM
Hi gotoluc,
   Your job to build a similar machine Skinner ?
Yes, same basic weight and mechanical system as Skimmer but a single rotor, total 8 feet high with no belts. Direct chain drive 12vdc PM motor at top and same direct chain drive 12vdcv PM motor as generator on bottom output shaft.
Luc
havuhung
Hi gotoluc,
I wish you success as you wish.
wopwops
In anyone in contact with CLaNZeR on this?
i_ron
Quote from: turbogt16v on June 10, 2014, 05:19:33 AM
agreed to disagree...
I wont bug you any more ,if you have a second look at video at 36 to 37sec,
you will see that the square that hold rood in place does not move same as the bar
   Yes, you are quite correct. This is called a gimbal mount. You can see the outer part of the gimbal move in unison with the angle of the rod. The inner part is hidden. Look at the gimbal to the left... see how wide the  space is?... much to wide for a mere slot action as has been proposed. Again, look at the left rod under the gimbal and you can see it moves in a circle. The gimbal holds the bearing that holds the lever/rod up. The length of rod beneath the gimbal moves opposite to the turning mechanism at the top of the rod, it inverts the motion. Ron
