1939 Gravity Power - multiply power by 1200%
Started by cipbranea, May 21, 2014, 01:38:08 AM
gotoluc
Quote from: ramset on June 27, 2014, 05:00:36 PM
Luc
but I don't think I can afford to make another set :-[
Perhaps setup a Paypal for this ?
While it will not be a fortune I can send some funds .
Thx
Chet
Thanks Chet, that's very kind of you to offer.
Let me think about it as I don't like to take other peoples money for something I no longer understand how it works.
It looked quite simple at first but the more I've been testing the effects the less I know what's going on ???
I'm sure I'm not the only one, there are many testing this.
After the weekend I'll get back to you if I think it's worth putting more into it.
Kind regards
Luc
ARMCORTEX
i_ron
Quote from: gotoluc on June 27, 2014, 03:44:39 PM
I actually didn't notice that. I guess it's not really rising but more coming forward with the mid plate angle changing.
Luc
Only partially correct Luc, the bottom is not free to rotate as it is locked by the three other stationary weights. When he rotates the upper weight forward he is changing the angle of the bottom weight plate causing the visible rise of the weight.  Note when he releases the upper weight the bottom weigh pulls the upper weight back to its normal run position.
What this is showing is the 'rod' is free not only to tilt in and out but tilt ahead and back, so it does require a ball or Cardan joint at the bottom. Where this is, is hard to say as the rod has no bend but is straight all the way down to the top of the bottom support works  and pivots around this point the sprocket below this
remains horizontally stable with no tilt to match the rod.
Ron
shylo
The long input arm that goes down to the  distribution plate , moves orbital, but is locked,It gives the illusion that it is rotating. It's locked around 90 degrees
Lock the input so it's 90 off  the bottom.
Still trying.....artv
ARMCORTEX
They are like 4 big wobbling plates out of phase.
Synchronized wobbling plate.
Of course something on top, or bottom, has the play for the tilt, same effect.
The 4 gears meet into one and support eachother via that link, so that they can counteract the load killing the inertia.
