KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
pomodoro
So as a guess what would you expect the voltmeter to read after I allow the electodes to equilibrate for 7 hours tomorrow?
profitis
I have no idea pomodoro but there will be something there.if you had used platinum(black) cathode(touching surface) and etched platinum anode(submerged) I would without a shred of doubt say you are going to get the same voltage tomorrow as today.carbons are dicey and clingy which is why I wanted you to coat with gold.
pomodoro
Don't worry, the gold will come. Well I also think there will be some difference, but very small. What if gold was plated what    then?
profitis
Lemmeputit2uthisway pomodoro,if your gold is adequately plated or if you use pure gold foil you'l get a voltage which will stubbornly absolutely refuse to go away.make sure you use ammonium sulfate plus sulfuric for wetability if you do this.
pomodoro
Now one last grilling profitis, before the gold, I'm going to put this cell under hydrogen, I still think there won't be much voltage difference between electrodes, what do you think?
