KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
You may proceed with the platinized Pt foil from the conductivity cell meantime and the treated Ag mr pomodoro.it will not fail you.leakage is the only concern and if H2 is piped through periodicly we can eliminate that completely.you can seal when the behaviour is as expected.we want the maximum power from overpotential differences that's all.
pomodoro
Good news. I have small amounts of ammonium tetrachloropalladate, potassium hexachloropalladate,PdCl2 and 1.5 cm of PD wire about 1mm diameter. I also have some ammoniumtetrachloroplatinate,chloroplatinic acid and gold chloride. So think carefully of the best cell we can possibly have first up!
pomodoro
Here is what I plan to build. It should keep the h2 in permanently don't you think? Others reading don't be shy and make any comments.
profitis
Here's the ideal for keeping out air mr pomodoro.this ensures continuous dilution and purging of traces of air.the electrolyte on the bottom,away from wire leads,hydrogen gas pumped through the tubes once or twice/day and clamped shut(clamp in this pic),the one pipe remaining attatched to H2 supply cylinder..you cannot use candle-type wax for sealing its very weak and breaks if a vaccuum is formed and it reacts with NaOH making soap which will poison our catalysts.hardcore silicone is best.I  melt the rims of this plastic pill container with a cigarette lighter to seal totaly.I melt around the wires enough to seal. What metal are your lead wires made of pomodoro??
profitis
Your setup will work for a few days but it won't be a permanent seal.oxygen in the air will be sucked in through the electrolyte via diffusion and it does this with quite a lot of force.is your flask-neck rough glass or smooth? What is that large metal disk in your pic?
