KARPEN PILE
Started by Philip Hardcastle, May 22, 2014, 10:41:32 PM
profitis
 adequately gas exposed palladium would remove traces O2 from your industrial h2 by instant catalytic recombination H2+O2>H2o.or you could just float some platinized asbestos fluff ontop electrolyte.
pomodoro
Voltage recovered back to +146 but then dropped to 8. Even opening to oxygen only raised it back to 150. Something screwed up, I think, after passing the 6v. no time to check today.  I will try plating gold for the next test.
profitis
 carbons are very unpredictable pomodoro it takes long time to equilibrate due to van der waals.tell me something before you plate gold,is that glassy C patch rough or smooth and is that 0.1microamp that mark E is refering to at the base of the  discharge curve or top
pomodoro
Smooth.  There was basically no current out of this. 0.1 I saw just for a split second. It did discharge because the volts dropped to zero.  Area is quite small, diameter is probably 3-4 mm. I have no more industrial h2 for other tests.
profitis
At least you proved that the chinese laborarory tests are consistent with reality.smooth glassy carbon at 4mm is minuscule surface area but it should be ok to make out voltages.plate that gold thick pomodoro,we don't want any interference from the underlying carbon.use wetting agent,ammonium sulfate added to your h2so4 for this next test.sulfuric sol does not wet surfaces well.
