Is Faraday´s Induction Law correct?
Started by hanon, June 11, 2014, 03:47:21 PM
hanon
Source of the image: New Energy Technologies, Issue 2,  Sept-Oct 2001
Gennady Nikolaev on the existance of a second magnetic field (scalar magnetic field)  --->  "...in the space where total vectorial magnetic field of two magnets is zero, the total value of scalar magnetic field of two magnets is maximal."  ..."this field do not interact with ferromagnetic materials." ....
hanon
In the next link you can download the book by Stefan Marinov "Divine Electromagnetism"
Marinov also proposed, as Nikolaev, the existance of a scalar magnetic field. The machines based on this scalar magnetic field were called by Marinov as "S-machines" and, in opposition to common "B-machines", those device can create overunity effect:
http://zaryad.com/wp-content/uploads/2012/10/Stefan-Marinov.pdf
He proposed the magnet shape "Siberian Colia" or also "Siberian Coliu" to get that OU effect
hanon
A great lecture about WEBER ELECTRODYNAMICS  and why it is superior to Maxwell EM theory.  By Prof. Andre Koch Torres Assis in 2010. A theory developed by Ampere, Gauss, Weber, Riemann but, sadly, forgotten.
http://www.worldsci.org/php/index.php?tab0=More&tab1=Media&tab2=Display&id=312
Do not miss it !!.   I attach below the slides.
hanon
I have uploaded the presentation of Weber Electrodynamics into Youtube for easy broadcasting
A theory which predicts longitudinal forces, as been proved experimentaly, but sadly forgotten after the advent of the Maxwell equations. Please see this lecture by Prof. Andre Koch Torres Assis:
https://www.youtube.com/watch?v=MJecZQwPgpI
Also here some good papers about the history of this theory:  [size=78%]https://es.scribd.com/doc/272067798/Ampere-Weber-Electrodynamics-History[/size]
hanon
I have found references to an electrodynamics theory developed by Hertz (Hertz Electrodynamics) which does not require Special Relativity to correct the flawed points into Maxwell´s equations , and include Lorentz force into the induction equation. Therefore Lorentz force is not required as an external term to be used at the same time that Maxwell´s equations:
http://www.angelfire.com/sc3/elmag/
Quote from: On Hertz's Invariant Form of Maxwell's Equations  by T. E. Phipps
The failure of Maxwell's equations to exhibit invariance under the Galilean transformation was corrected by Hertz through a simple, but today largely forgotten, mathematical trick. This involves substituting total (convective) time derivatives for partial time derivatives wherever the latter appear in Maxwell's equations. By this means Hertz derived a formally Galilean-invariant covering theory of Maxwell's vacuum electrodynamics - which, however, was not space-time symmetrical
