Fundamentals of FREE ENERGY generation with a transformer. Experiment #1
Started by tarakan, June 12, 2014, 06:22:08 PM
tarakan
Hello.
I would like to address my question to those members of the forum who have prior experience in developing electronics professionally.
I had recently found an article (in Russian) that seems to summarize all my theories of how Free Energy devices that involve some sort of transformer may work.
https://translate.google.com/translate?sl=auto&tl=en&js=y&prev=_t&hl=en&ie=UTF-8&u=http%3A%2F%2Fhalerman.narod.ru%2FTTCG%2FKapanadze.htm&edit-text=
http://halerman.narod.ru/TTCG/Kapanadze.htm
This article talks about efficient ways of exciting a Tesla Transformer using an oscillator that is Phase Lock Looped to the self-frequency of the Tesla Transformer SECONDARY and that applies an occasional impulse to maintain the oscillations.
The timing of this impulse is very critical and it compared to the automobile ignition timing.
If, indeed, transformers that work in the impulse mode can create Free Energy from Aether entering the device as the magnetic field collapses, than it makes a perfect sense to excite them at their resonant self-frequency and to measure the voltages and currents that exist inside the transformer after a square impulse was applied.
I would like to test different ferrite-core transformers and air-core transformers using this experimental rig.
1) Is occasional impulse method of driving a transformer more efficient than just using a transistor that is connected to the secondary for feedback and excites the primary?
2) Is this method better than the traditional Tesla Coil method of adding a pulse from a capacitor bank as voltage on the secondary decays?
My hypothesis is that Mother Nature tends to generate harmonic oscillations and in doing so, additional energy may be drawn from the aether to add to the energy that was brought to the transformer by the input impulse.
I want to test all the possible "Free Energy" transformer devices using this jig.
http://s2.postimg.org/blri7r8a1/Scan_140612_0005.jpg
There are two ways to construct this device.
A traditional PLL synthesizer that uses the coil resonance as a clock source and a digital approach.
http://s9.postimg.org/p15zh2ypb/Scan_140612_0006.jpg
OR
A Microcontroller - DDS impulse generator that uses a frequency divider to measure the oscillator frequency and some kind of DDS to generate an impulse.
http://s28.postimg.org/u9dmakqel/Scan_140612_0003.jpg
Since my experiment will run in the 10KHz to 1MHz frequency, using a microcontroller directly would not be possible.
I would need some kind of ripple counter for this purpose.
Timing of the input impulse would be rather difficult. In case with traditional PLL, I would need a voltage-controlled oscillator that outputs a pulse every N number of oscillations.
In case with a microcontroller I would need to use an algorithm and circuity to time the pulse perfectly at very high frequencies.
So I will need to consider the time it takes to make a decision that the pulse has to occur and subtract it from the timing of the pulse.
I bought a http://www.analog.com/static/imported-files/data_sheets/AD9833.pdf
I am not sure how many steps are offered to shift the output phase.
I see this in the datasheet:
The analog output from the AD9833 is
fMCLK/228 × FREQREG
where FREQREG is the value loaded into the selected frequency
register. This signal is phase shifted by
2π/4096 × PHASEREG
where PHASEREG is the value contained in the selected phase
register
But Pi is an irrational number...
Maybe I should buy a different Analog Devices IC to generate the pulse.
A triangle output of AD 9833 makes it suitable, however there are very few examples of how to interface it to Arduino.
I am designing a circuit that would be able to excite any RCL resonator at the 10KHz to 1MHz frequency range.
I would need to connect the circuit to Arduino anyways because I would like to see the output frequency on a text LCD and I would like some rotary encoder inputs to tweak some variables.
Help me design a circuit, please.
tarakan
Quote from: vasik041 on June 13, 2014, 03:08:07 AM
Here a project which can be useful
http://nutsvolts.texterity.com/nutsvolts/201404/?folio=20#pg20
Sounds great for the KHz frequency. Thank you.
I am thinking of using a high frequencyPWM IC that would run at the same clock source as the ripple counter.
Both the ripple counter and the PWM IC would run at higher clock frequency than the Arduino, but since the input impulse will happen rather occasionaly, Arduino will have time to do the math to position it.
https://www.sparkfun.com/datasheets/Components/General/tlc5940.pdf
Maybe a PULSE - POSITION MODULATION  IC such as http://www.analog.com/static/imported-files/data_sheets/AD9560.pdf
BUT...
I WANT TO ANNOUNCE that instead of trying to replicate
Kapanadze Generator, Alula 0083, Hubbard Generator, Martinez Generator, Tesla Coil overunity, Ferroresonance experiments, etc,
I want to draw a common denominator from all the above TRANSFORMER-BASED overunity circuits.
Instead of messing with complex, analog circuits I want to design a JIG that would allow me to test all kinds of transformers at self-resonance.
There is a common theory that the magnetic field collapse brings in "radiant energy". Than lets test it. I want my transformers to be impulse driven and I want to measure all the input and all the output and than, if I see a sign of overunity, I will design a more optimized circuit for the task.
But for now I am building a TEST JIG.
Instead of trying to decipher what the inventor (or a scammer) had in mind when a specific circuit was designed, I want to take a universal approach.
If two frequencies have to mix inside a transformer, so be it. This will be the next addition to my circuit.
PLEASE, PLEASE, PLEASE
I want your engineering advice, and I want you to criticize and check my ideas for sanity and practicality.
You are welcome to take on my project, but please inform me of every step you undertake so I can repeat it and learn. I will make sure that I will document everything.
I actually WANT an experienced engineer to take on my project since I am not so great at designing my own circuits.
Help me design this jig, please. I promise to keep this circuit open- source. It will be a very handy RCL resonant frequency meter for any hobbyist.
It will track small amplitude - frequency relationships in the resonator.
If it works, I will put on my Guy Fawkes mask and distribute the results to everyone's doorstep.
THANK YOU.
forest
he he if that would be so easy I would take a team of "experienced engineers to take on my project " and solve riddle in few months [/size] :P
vasik041
QuoteI want to draw a common denominator from all the above TRANSFORMER-BASED overunity circuits.
Why you think that there is a common denominator?
P.S. Some more practical circuits here http://vasik041.files.wordpress.com/2013/11/fe_basics.pdf
