James Hardy Water Wheel Experiment.
Started by TommeyLReed, June 26, 2014, 09:36:52 PM
mscoffman
The danger of operating a submerged pump, on utility current caused me to think...Suppose the pump motor was designed to operate on
a landscape voltage of 32 volts instead. But instead the guy overloaded the pump motor by operating it on rectified 120Vdc or even
120Vac. This overload could cause PM permanent magnets in the motor to be erased, showing overunity while doing so.
The standard water utility pressure is 80psi, in the video it looks like water curve is being driven above 80psi, suggesting again overload
driving of the pump. The flowing water would supply cooling to the pump, so overloading wouldn't immediately destroy it.
The other claim was the generator was modified. Those unmarked white capacitors look suspicious to me. They are supposed to
be in the excitation field. Maybe they are batteries, causing temporary overunity.
Do be careful, that guy was wearing rubber gloves I believe. Chlorinated city water is plenty low enough in resistance.
Two things: you can build a 1:1 line isolation transformer out of two hefty line transformers hooked up back-to-back which gets rid of
ground conductance problems. Two, consider having a helper who can stop the line current should anything untoward happen.
:S:MarkSCoffman
TommeyLReed
Hi Mark,
I understand the city water electrolite up here in N. Pa I have good well water.
That does not mean I want to bath in the electricity.
I'm setting up a simple test as I write.
Tom...
TommeyLReed
First pump test using 1.5 ID output, could not get watts due to 30gal running out in seconds..
https://www.youtube.com/watch?v=WqjbVS03INs
Tom
TommeyLReed
