The Propane Air Engine Project
Started by TommeyLReed, June 28, 2014, 09:23:23 AM
TommeyLReed
Hi All,
I'm testing a air run on this valve I design, if everything works out I will put in on the ac system and test run using the compressor before adding propane.
https://www.youtube.com/watch?v=h1dvGFoL6lM
Tom  Cheesy
TommeyLReed
Hi All,
I did a test run and my electric valves are not fast enough, just wanted to make shore before I go back to mechanical linear valves.
I also found that my 1/4 input ports are too small, need 1/2 or better, this will allow better flow of expanding gas.
https://www.youtube.com/watch?v=42CjyHjMfxg
Tom
TommeyLReed
This is a IC engine running much faster, but lots of cfm. Afro
https://www.youtube.com/watch?v=rJ0e-kM27CM
Tom.
TommeyLReed
Hi All,
OK, now there just might be something to a close loop system wiith a IC engine.   8)
This is the first test using the AC compressor to compress air to run the IC engine two stroke design.
Enjoy the show.
https://www.youtube.com/watch?v=Pa_4cxA84cU
Tom  :o
TommeyLReed
Hi All,
OK this is the best way to convert linear into direct rotational energy.
https://www.youtube.com/watch?v=TNm6IcQdK-8
Tom
